Blank page with passbolt badge after authentication
Server worked 2years with no issues. But last week lost access to all passwords.
All users after authorization have blank page with no access to passwords.
After healthcheck found an issue and fixed it: [FAIL] The temporary directory and its content are not writable.
Restarted the server, it is passing now, but issue still persist. Any ideas what I can else to try?
Passbolt version - 2.13.5
# sudo -H -u nginx bash -c "/var/www/passbolt/bin/cake passbolt healthcheck"
 [PASS] PHP version 7.3.33.
 [PASS] Full base url is set to https://passbolt....
 [PASS] 23 tables found
 [FAIL] This installation is not up to date. Currently using 2.13.5 and it should be v4.0.0.
Hi @alexant14 Welcome to the forum!
There are many posts about this recently.
  • v4 extension requires at least v3 API (you have 2.13.5)
  • v3.x API requires at least php7.4
  • You need to upgrade your passbolt
  • temporary access is restored with v3 extension downgrade
See Passbolt v4 beta testing is now open 🚀 - #2 by garrett
Thank you for the fast reply,
I was able to find v3 extension and it solved issue temporary.
Now working on creating new passbolt server and moving there data.
Thank you @alexant14
We understand the frustration, it was very hard for us to maintain the retro compatibility for such a long period of time. Keep in mind that 2.13.5 was released mid 2020 and it was too complex to ensure that compatibility for all the platform.
All the guide to upgrade the version are there: Passbolt Help | Upgrade
And indeed, setup a new server will be much simpler.
Let us know
