This was a clean VM install from the paid for version (OVA file download so out of the box install).
Worked fine on first computer, then when I go to retrieve my username on a second machine and it needs to send me an email it never arrives.
I manually run:
var/www/passbolt/bin/cake EmailQueue.sender
And get:
Exception: SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘EmailQueue.to’ in ‘field list’ in [/var/www/passbolt/vendor/cakephp/cakephp/src/Database/Statement/MysqlStatement.php, line 39]
I’ve read on forums there can be a schema mismatch following upgrades but given I’ve installed the latest OVA I don’t see how this is the problem here.
Can you try clearing the cakephp cache? ./bin/cake cache clear_all sudo su -s /bin/bash -c "./bin/cake migrations migrate" www-data
The previous version of the model (installed in the initial migration and droped after, to ensure v1 upgrade path) might still be loaded in cache. It’s a bit of a mystery to us as of why the application end up in this state in some rare occasions.
Feel free to contact us on support@passbolt.com since you’re using the pro edition, we can look into it together.
Hi I’ve since resolved by doing a fresh Ubuntu install and deploying pass bolt on there rather than using the OVA. Seems strange the issue would be in the ore built OVA. No upgrades or anything.
