Hey there trying to update to the latest community edition on DigitalOcean droplet. Am getting this error:
2021/04/14 16:36:28 [error] 4926#4926: *23 FastCGI sent in stderr: “PHP message: PHP Warning: require(/var/www/passbolt/vendor/composer/…/symfony/polyfill-ctype/bootstrap.php): failed to open stream: Permission denied in /var/www/passbolt/vendor/composer/autoload_real.php on line 69
PHP message: PHP Fatal error: require(): Failed opening required ‘/var/www/passbolt/vendor/composer/…/symfony/polyfill-ctype/bootstrap.php’ (include_path=’.:/usr/share/php’) in /var/www/passbolt/vendor/composer/autoload_real.php on line 69” while reading response header from upstream, client: 97.104.124.193, server: passbolt.company.com, request: “GET / HTTP/1.1”, upstream: “fastcgi://127.0.0.1:9000”, host: “domain”
2021/04/14 16:36:30 [error] 4926#4926: *23 FastCGI sent in stderr: “PHP message: PHP Warning: require(/var/www/passbolt/vendor/composer/…/symfony/polyfill-ctype/bootstrap.php): failed to open stream: Permission denied in /var/www/passbolt/vendor/composer/autoload_real.php on line 69
PHP message: PHP Fatal error: require(): Failed opening required ‘/var/www/passbolt/vendor/composer/…/symfony/polyfill-ctype/bootstrap.php’ (include_path=’.:/usr/share/php’) in /var/www/passbolt/vendor/composer/autoload_real.php on line 69” while reading response header from upstream, client: 97.104.124.193, server: domain, request: “GET / HTTP/1.1”, upstream: “fastcgi://127.0.0.1:9000”, host: “domain”
So appears to be an odd permission issue? Any help is appreciated.
