I have run into a problem where a previously working install of Passbolt in a Docker container on a Synology NAS has stopped working after an unexpected shutdown (due to a power cut) of the server.
Everything was working fine prior to the power cut. I was able to access Passbolt on the desired subdomain and domain. The SSL and port forwarding in the router were all working okay.
Now the container starts but report it is ‘unhealthy’. The last output from the container is “Failed to connect to localhost port 8080 : Connection refused”. I have checked that port 8080 is not being used by another process.
I would like to try to resolve this without a full re-install as there are some users who have stored passwords that I would like to retain if possible.
I have tried re-starting the container serveral times, always with the same result. I have tried stopping all other containers and starting Passbolt on its own with no success (and the same error).
The original install was done with this guide :
I suspect the problem could be reproduced by installing as above and doing a hard-shutdown (power cut) to the server.
I have since bought a UPS. : -)
Links in this post have been removed as new users are not allowed more than 2 links in a post.
Thanks in advance to anyone who can help.
I have read intro post : link removed
Server : Synology NAS, DSM 7.1.1-42962 Update 4
docker compose details:
version: "3.9"
db:
image: mariadb:jammy
container_name: Passbolt-DB
hostname: passbolt-db
mem_limit: 512m
mem_reservation: 128m
cpu_shares: 768
security_opt:
- no-new-privileges:true
healthcheck:
test: ["CMD-SHELL", "mysqladmin ping -P 3306 -prootpass | grep 'mysqld is alive' || exit 1"]
- /volume1/docker/passbolt/db:/var/lib/mysql:rw
TZ: Australia/Melbourne
MYSQL_ROOT_PASSWORD: rootpass
MYSQL_DATABASE: passbolt
MYSQL_USER: passboltuser
MYSQL_PASSWORD: passboltpass
restart: on-failure:5
image: passbolt/passbolt:latest-ce-non-root
command:
- /bin/bash
- -c
- /usr/bin/wait-for.sh -t 0 db:3306 -- /docker-entrypoint.sh
hostname: passbolt
mem_limit: 1g
cpu_shares: 512
security_opt:
healthcheck:
test: curl -f *removed* || exit 1
- 9475:8080
- /volume1/docker/passbolt/gpg:/etc/passbolt/gpg:rw
- /volume1/docker/passbolt/jwt:/etc/passbolt/jwt:rw
DEBUG: false
APP_FULL_BASE_URL: *removed*
DATASOURCES_DEFAULT_HOST: passbolt-db
DATASOURCES_DEFAULT_USERNAME: passboltuser
DATASOURCES_DEFAULT_PASSWORD: passboltpass
DATASOURCES_DEFAULT_DATABASE: passbolt
PASSBOLT_REGISTRATION_PUBLIC: true
EMAIL_DEFAULT_FROM: *removed*
EMAIL_TRANSPORT_DEFAULT_HOST: *removed*
EMAIL_TRANSPORT_DEFAULT_PORT: 25
EMAIL_TRANSPORT_DEFAULT_USERNAME: *removed*
EMAIL_TRANSPORT_DEFAULT_PASSWORD: *removed*
depends_on:
db:
condition: service_started
Healthcheck :
[PASS] PHP version 7.4.33.
[PASS] Full base url is set to *link removed*
[HELP] Check *link removed*
[HELP] cURL Error (6) Could not resolve host: *link removed - but it did work with this link*
[FAIL] The application is not able to connect to the database.
[HELP] Double check the host, database name, username and password in /etc/passbolt/passbolt.php.
[HELP] Make sure the database exists and is accessible for the given database user.
[FAIL] No table found
[HELP] sudo su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake passbolt install" www-data
[HELP] sudo su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake migrations migrate --no-lock" www-data
[HELP] See. *link removed*
[HELP] you can try:
[FAIL] Could not connect to passbolt repository to check versions It is not possible check if your version is up to date.
[WARN] Registration is open to everyone.
[HELP] Or set passbolt.registration.public to false in /etc/passbolt/passbolt.php.
SMTP Settings
[FAIL] 12 error(s) found. Hang in there!
