Hello. I have installed the Passbolt application on my centos 7 based server. I have a problem in the e-mail smtp part during the installation phase. I use outlook.com as e-mail. In the test mail sending part
“Email could not be sent: stream_socket_client(): unable to connect to tcp://smtp-mail.outlook.com.:587 (Permission denied)”
#!!! This avc can be allowed using one of the these booleans: #httpd_can_network_connect, httpd_can_sendmail, nis_enabled
allow httpd_t smtp_port_t:tcp_socket name_connect;
hello. I did the steps you said, but my problem still persists. If I install another linux-based server instead of Centos, I wonder if the problem will be fixed? ( Ubuntu, Debian, Oracle ).
Hi there
After _jc restart, my problem is solved, now I have installed and using the passbolt application without problems. Thank you for your help. Good work.
Thank you for the feedback. I will keep you posted when our passbolt-selinux package will be updated with the fix. So you will be able to use your SMTP provider with selinux enabled.
