How to configure SMTP on CentOS7 once I completed the passbolt installation? Is possible this, or I should to install again?
Hi @rfernandez and welcome to Passbolt Community forum
If you already installed passbolt on your CentOS7 server but made a mistake with SMTP configuration, you can open passbolt PHP configuration file /var/www/passbolt/config/passbolt.php and search for the EmailTransport section:
'EmailTransport' => [
'default' => [
'host' => 'localhost',
'port' => 587,
'username' => null,
'password' => null,
'tls' => null,
//'timeout' => 30,
//'client' => null,
//'url' => null,
Once done, you can check your SMTP configuration is working by executing the email test command from the /var/www/passbolt directory:
sudo -H -u nginx bash -c "./bin/cake passbolt send_test_email --recipient=youremail@domain.com"
Thank you very much _jc for your answer.
You’re welcome By the way, if you are interested, RPM package for CentOS 7 is coming soon.
