we have a problem with passbolt emails. Sometimes they are sent with no problem and sometimes they are not sent at all. I checked the email_queue table in a database and found some records and an error message.
Yes I know requirements of our mail server because we are using Exchange Online mail server. Basically there are three main methods how to send emails from application (or device) to the Exchange Online (M365): MS Documentation We are using the third option - SMTP Relay Connector because we want to send emails to external parties and we are using the Azure AD MFA
Yes it is available because this method and this configuration is working on other systems (and devices)
We are using passbolt in docker compose and I checked the SMTP settings in the docker-compose.yml file multiple times - they are correct as the MS documentation states
Our DNS records are indeed pointed to our private DNS servers but if our private DNS servers can not resolve the DNS they are forwarding a request to the Google DNS servers (8.8.8.8, 8.8.4.4).
In this scenario I think there is no problem with DNS resolving.
@Milan
I have not done this myself, but here are some thoughts.
You will either need to whitelist the ip address and use a username/password approach, or use a certificate. I’m not sure which of these would explain intermittent delivery, but if your passbolt host is not on a fixed ip address and it’s ip address changes and then does not qualify under the whitelisting, maybe this is why.
The use of a certificate is more difficult as I believe passbolt does not have this option documented for use (and it will likely require some modification of your config files), but you would maybe be looking to do something like this (stackoverflow) which addresses the connection itself, versus the encryption of the message content.
The certificate is created on the M365 side of things, and installed for use on the passbolt host. Again, just thoughts based on your details provided. This would go under
@garrett
Our passbolt server have a static, public IP address which is configured in our SMTP Relay connector in the Exchange Online admin center. Also this public static IP is configured in the DNS spf record within our public (M365) domain.
Anyway I will probably try to use a certificate instead of a static public IP address because idk what else I can do to fix this issue. I will keep trying to solve it.
@garrett Can I ask if passbolt is supporting and using the TLS 1.2 protocol? If not, then the protocol TLS 1.0 or TLS 1.1 is used which is blocked in the M365 tenants and this will be the problem.
@Milan I’m re-reading the M365 link you provided. I now believe the issue is that it will not permit username/password authentication. I was wrong when I gave the options above - it’s either whitelisting by ip address on your tenant settings, or requirement of a cert. If the ip address has been whitelisted, I think the username/password fields variables need to be removed, or each set to null. If one does not work, try the other.
And the EMAIL_DEFAULT_FROM must be a legit email or alias in your organization.
SMTP Relay is configured correctly, port 25 is opened (not blocked - i know it because i tried a tcp ping from passbolt server). So in the powershell it is working but in the passbolt it does not. I assume that passbolt somehow can not realize this type of email sending (SMTP Relay to Exchange Online). If I made a mistake somewhere I will be glad to find it but I can not see a difference between the passbolt configuration and the powershell configuration on my local machine.
@Milan I also read this error you are showing from the passbolt test could be related to Azure AD being used - which may explain why your local machine is working fine.
