Hello, Do you know how I can fix this error?
PLS Help
fopen: failed to open stream: operation failed
Can you tell us more about your certificate? Did you generate it yourself or with a tool like letsencrypt? According to this error it looks like the domain name do not match.
I have wild card ssl cert and I add it to passbolt. everything works fine. I have only this error.
I bought it from ssls.com
It could be a false negative then, if your browser is fine with the certifcate it should be fine.
Yeah my browser is fine firefox is fine both green https.
