I wanted to change port and what i found in community was to change nginx.passbolt.conf . I changed the port but it does not help. Just a black screen comes.
Could anyone help me ?
Thank you
Abdul
Thank you
Abdul
Hi @razzak ,
If you want to change port, you have to change also the 'fullBaseUrl' value in /etc/passbolt/passbolt.php file, eg.
'App' => [
'fullBaseUrl' => 'https://passbolt.domain.tld:8080',
Thank you for the help
cheers
