I’m looking for a tutorial on how I can try the open source software on Windows local host, maybe with XAMPP.
On my Plesk Ubuntu server I cannot install by SSH to avoid conflict so, I wanna test on local host then transfer by FTP.
Any advice on how I can do?
Once download and installed XAMPP I don’t know what steps follow to download and install passbolt, also never find nothing that helps here and on search engines.
You won’t be able to “transfer” passbolt files through FTP. Our recommendation is to install passbolt on a vanilla server without other software on it to avoid conflicts and for security.
If you want to host passbolt aside your plesk setup, maybe you should go for the docker install, to isolate passbolt.
