In the profile settings it is still not possible to upload avatars. Any file format used is only answered with “internal error”. Tested on licensed pro version [2.13.5] 2020-07-30
This may happen if you do not have the directory /webroot/img/public/Avatar/
writable by the web server (www-data user). This should be mentioned in the healthcheck. If that still does not solve the problem, can you check in logs/error.log
for more information about the problem.
i am also havin the same issue.
i gave all the proper rights and would still get the same error.
i even tried creating the file which elas still would not work. does anyone have a solution to resolve this.
@admian can you post the result of logs/error.log
here, so we can see that internal error details?
