When I upload a .jpeg profile image, it doesn’t upload, at all. It just says “Error: Not Found”
A similar error to Internal error occurs when uploading avatars
What should I do? Thanks!
Hi @rion,
Welcome to the forum!
Which OS and install version are you running, and which browser/version are you using?
Also, is this a fresh install or has it been upgraded from a previous version?
Hello! Thanks for the welcome. Also, I’m sorry I forgot to include that, I’m using Windows on Chrome. I can’t find the installation version, but it is a fresh installation of Passbolt. I’m using the AWS marketplace image: https://aws.amazon.com/marketplace/pp/B08PDGS3ML
If I’m correct, this is using Debian.
@rion Thanks, that’s very helpful.
Try uploading a file with extension .jpg, .png, or .gif. I have been told that .jpeg is not accepted at the moment. Post back, thanks.
Thanks! That worked! I didn’t know that was the problem.
Oh, and I just realized I have another problem, so I create a new topic for that.
