Dear all,
Iβm unable to upload avatars.
This may be related to #3320 (Internal error occurs when uploading avatars), but the answers provided there are not that in-depth to help me track down the problem.
2021-05-18 01:48:23 Error: The file "Avatar/4d/dc/19/ea44b5b1db2e49d385bb071ff94ef73e/ea44b5b1db2e49d385bb071ff94ef73e.png" was not found.
2021-05-18 01:48:23 Error: [Burzum\FileStorage\Storage\StorageException] The file "Avatar/4d/dc/19/ea44b5b1db2e49d385bb071ff94ef73e/ea44b5b1db2e49d385bb071ff94ef73e.png" was not found. (/usr/share/php/passbolt/vendor/burzum/cakephp-file-storage/src/Storage/Listener/AbstractListener.php:366)
Caused by: [Burzum\FileStorage\Storage\StorageException] The file "Avatar/4d/dc/19/ea44b5b1db2e49d385bb071ff94ef73e/ea44b5b1db2e49d385bb071ff94ef73e.png" was not found. (/usr/share/php/passbolt/vendor/burzum/cakephp-file-storage/src/Storage/Listener/AbstractListener.php:395)
Caused by: [Gaufrette\Exception\FileNotFound] The file "Avatar/4d/dc/19/ea44b5b1db2e49d385bb071ff94ef73e/ea44b5b1db2e49d385bb071ff94ef73e.png" was not found. (/usr/share/php/passbolt/vendor/knplabs/gaufrette/src/Gaufrette/Filesystem.php:292)
Request URL: /users/e582cebb-ad96-4f8e-b33d-444a740c41ab.json?api-version=v2
2021-05-18 01:49:51 Error: [App\Error\Exception\ValidationException] Could not validate user data. (/usr/share/php/passbolt/src/Controller/Users/UsersEditController.php:59)
Healthcheck is good:
# sudo -H -u www-data bash -c "/usr/share/php/passbolt/bin/cake passbolt healthcheck --verbose"
[PASS] PHP version 7.4.3.
[PASS] Full base url is set to https://pass.xxxxxxxxx
[PASS] 33 tables found
[PASS] The environment variable GNUPGHOME is set to /etc/passbolt/.gnupg.
[PASS] The directory /etc/passbolt/.gnupg containing the keyring is writable by the webserver user.
[PASS] Using latest passbolt version (3.1.0).
Everything works fine, except saving avatars.
My public image directory is: /usr/share/php/passbolt/webroot/img/public/.
My file storage table looks like this (some fields truncated) for readability:
MariaDB [passbolt]> select * from file_storage;
| id | user_id | fo | model | filename | filesize | mime_type | extension | hash | path | adapter | created | modified |
| 60e | 7706885f | a0 | Avatar | kisspng- | 498629 | image/png | png | c040 | Avatar/38/c0/aa/60eca304d7074a8f83360a9c9906da1f/60eca304d7074a8f83360a9c9906da1f.png | Local | 2019-06-25 05:57:55 | 2019-06-25 05:57:55 |
| c04 | 5a1bd961 | 5a | Avatar | peace.jp | 9291 | image/jpeg | jpg | c38e | Avatar/c7/fc/59/c04bbd737857496d8ab0a00adb29ae5c/c04bbd737857496d8ab0a00adb29ae5c.jpg | Local | 2019-06-24 13:38:48 | 2019-06-24 13:38:48 |
| ea4 | e582cebb | 7b | Avatar | 580b585b | 34123 | image/png | png | 8e1b | Avatar/4d/dc/19/ea44b5b1db2e49d385bb071ff94ef73e/ea44b5b1db2e49d385bb071ff94ef73e.png | Local | 2020-07-10 07:35:13 | 2020-07-10 07:35:13 |
| fff | 5a1d3293 | 5a | Avatar | test.jpg | 183760 | image/jpeg | jpg | 2a9d | Avatar/f3/9c/67/fff05c7575b2486681b2778d9ef2f608/fff05c7575b2486681b2778d9ef2f608.jpg | Local | 2019-09-03 08:22:40 | 2019-09-03 08:22:40 |
4 rows in set (0.001 sec)
It appears a directory or two has been created while uploading the avatar from my user profile page:
# l /usr/share/php/passbolt/webroot/img/public/Avatar/
total 32
drwxr-xr-x 8 www-data www-data 4096 2021-05-18 03:48:23.06 .
drwxr-xr-x 3 www-data www-data 4096 2021-05-18 03:12:49.57 ..
drwxr-xr-x 3 www-data www-data 4096 2021-05-18 03:20:38.41 22
drwxr-xr-x 3 www-data www-data 4096 2021-05-18 03:47:56.39 31
drwxr-xr-x 3 www-data www-data 4096 2021-05-18 03:48:23.06 39
drwxr-xr-x 3 www-data www-data 4096 2021-05-18 03:12:49.57 a9
drwxr-xr-x 3 www-data www-data 4096 2021-05-18 03:48:07.61 e6
drwxr-xr-x 3 www-data www-data 4096 2021-05-18 03:20:51.54 f0
[root@passbolt:~] # tree /usr/share/php/passbolt/webroot/img/public/Avatar/
βββ 22
β βββ 76
β βββ e0
β βββ feac38c637e447fcaac9fc23109cc795
βββ 31
β βββ 99
β βββ 57
β βββ 4c4c788599e44a298b947c00646fe56c
βββ 39
β βββ 72
β βββ 7e
β βββ c5423dc1da8f4ad69cdf3d62f11d7511
βββ a9
β βββ 8d
β βββ 44
β βββ 88cd247862be45e5bc043c5ab48843ed
βββ e6
β βββ 95
β βββ 26
β βββ 053dad6c865d4a5cb73c31e4ec95a63d
βββ f0
βββ cc
βββ b3
βββ 788e3eb4574f4f4e9302671e7a9c9ed7
24 directories, 6 files
β¦so my config setting canβt be that wrong: /etc/passbolt/file_storage.php
<?php
use Cake\Core\Configure;
use Burzum\FileStorage\Storage\StorageUtils;
use Burzum\FileStorage\Storage\StorageManager;
// File storage and images
Configure::write('ImageStorage.adapter', 'Local');
#Configure::write('ImageStorage.basePath', WWW_ROOT . 'img' . DS . 'public' . DS);
Configure::write('ImageStorage.basePath', '/usr/share/php/passbolt/webroot/img/public/');
Configure::write('ImageStorage.publicPath', 'img' . DS . 'public' . DS);
Configure::write('FileStorage', array(
// Configure the `basePath` for the Local adapter, not needed when not using it
# 'basePath' => APP . 'FileStorage' . DS,
# /passbolt/webroot/img/public/images/Avatar/65/90/13/5ab52135926c44ee8c384c6ac0a88a1b/5ab52135926c44ee8c384c6ac0a88a1b.jpg
'basePath' => '/usr/share/php/passbolt/webroot/img/public/',
β¦but still, these donβt make it into the database, and all error messages I get (apart from the frontend: An Internal Error Has Occurred) are the ones I posted from the log file above.
No idea. I hoped to fix this issue by kinda doing a semi-fresh start. We started out in April 2019 with passbolt_pro_ubuntu_installer.sh, avatars worked then, but in the meantime we made several upgrades and some time in 2020, avatars stopped working.
Iβm on Ubuntu 20.04. Iβve followed a mix of manual install instructions and the ones for the Ubuntu package.
Any pointers are appreciated.
β¦everything is great now! Avatars save and load just fine.
