Symlink
February 25, 2021, 2:21pm
#1
I followed procedure :
Updated to ubuntu 20.04
I ran all the procedure all the way to :
sudo dpkg-reconfigure passbolt-ce-server
Answer the following way:
No to mysql configuration
Yes to nginx configuration
You can then select the SSL method that suits best your needs.
I am at the select your SSL fullchain key (because I selected manual SSL because during the first install I generated the SSL certificate myself)
I donβt see my key.pem nor my cert.pem anywhere on the server anymore.
Am I correct in assuming I need those original files or I can generate new ones using this :
Thanks again for your time and help.
diego
February 25, 2021, 2:44pm
#2
Hi @Symlink ,
The ubuntu package should copy your certs from the initial location to a known location. This location should be:
/etc/ssl/certs/your_cert_filename
and
/etc/ssl/private/your_key_filename
For your cert and key respectively. Also these locations should be reflected on your /etc/passbolt/nginx-ssl.conf on the lines starting with:
ssl_certificate
ssl_certificate_key
If this is not the case let us know.
Symlink
February 25, 2021, 3:52pm
#3
Hi diego,
Thanks for your support. I am lost
I tried to manual ssl with :
/etc/ssl/certs/passbolt_certificate.crt
and
/etc/ssl/certs/passbolt_private.key
That were present in the folder.
Here is the output of ls -al of my /etc/ssl/certs/ folder :
lrwxrwxrwx 1 root root 45 Feb 14 2019 02265526.0 β Entrust_Root_Certification_Authority_-G2.pem
lrwxrwxrwx 1 root root 36 Feb 14 2019 03179a64.0 β Staat_der_Nederlanden_EV_Root_CA.pem
lrwxrwxrwx 1 root root 27 Feb 14 2019 062cdee6.0 β GlobalSign_Root_CA -R3.pem
lrwxrwxrwx 1 root root 25 Feb 14 2019 064e0aa9.0 β QuoVadis_Root_CA_2_G3.pem
lrwxrwxrwx 1 root root 50 Feb 14 2019 06dc52d5.0 β SSL.com_EV_Root_Certification_Authority_RSA_R2.pem
lrwxrwxrwx 1 root root 20 Feb 14 2019 080911ac.0 β QuoVadis_Root_CA.pem
lrwxrwxrwx 1 root root 54 Feb 14 2019 09789157.0 β Starfield_Services_Root_Certificate_Authority -G2.pem
lrwxrwxrwx 1 root root 15 Feb 24 13:09 0a775a30.0 β GTS_Root_R3.pem
lrwxrwxrwx 1 root root 16 Feb 14 2019 0b1b94ef.0 β CFCA_EV_ROOT.pem
lrwxrwxrwx 1 root root 44 Feb 14 2019 0bf05006.0 β SSL.com_Root_Certification_Authority_ECC.pem
lrwxrwxrwx 1 root root 34 Feb 14 2019 0c4c9b6c.0 β Global_Chambersign_Root -2008.pem
lrwxrwxrwx 1 root root 32 Feb 24 13:09 0f5dc4f3.0 β UCA_Extended_Validation_Root.pem
lrwxrwxrwx 1 root root 26 Feb 14 2019 0f6fa695.0 β GDCA_TrustAUTH_R5_ROOT.pem
lrwxrwxrwx 1 root root 15 Feb 24 13:09 1001acf7.0 β GTS_Root_R1.pem
lrwxrwxrwx 1 root root 46 Feb 14 2019 106f3e4d.0 β Entrust_Root_Certification_Authority -EC1.pem
lrwxrwxrwx 1 root root 49 Feb 14 2019 116bf586.0 β GeoTrust_Primary_Certification_Authority -G2.pem
lrwxrwxrwx 1 root root 27 Feb 24 13:09 14bc7599.0 β emSign_ECC_Root_CA -G3.pem
lrwxrwxrwx 1 root root 59 Feb 14 2019 1636090b.0 β Hellenic_Academic_and_Research_Institutions_RootCA_2011.pem
lrwxrwxrwx 1 root root 23 Feb 14 2019 18856ac4.0 β SecureSign_RootCA11.pem
lrwxrwxrwx 1 root root 21 Aug 5 2019 1b65a851 β ssl-cert-snakeoil.pem
lrwxrwxrwx 1 root root 21 Feb 24 13:09 1b65a851.0 β ssl-cert-snakeoil.pem
lrwxrwxrwx 1 root root 31 Feb 14 2019 1d3472b9.0 β GlobalSign_ECC_Root_CA -R5.pem
lrwxrwxrwx 1 root root 37 Feb 14 2019 1e08bfd1.0 β IdenTrust_Public_Sector_Root_CA_1.pem
lrwxrwxrwx 1 root root 32 Feb 14 2019 1e09d511.0 β T-TeleSec_GlobalRoot_Class_2.pem
lrwxrwxrwx 1 root root 38 Feb 14 2019 244b5494.0 β DigiCert_High_Assurance_EV_Root_CA.pem
lrwxrwxrwx 1 root root 23 Feb 24 13:09 2923b3f9.0 β emSign_Root_CA -G1.pem
lrwxrwxrwx 1 root root 20 Feb 14 2019 2ae6433e.0 β CA_Disig_Root_R2.pem
lrwxrwxrwx 1 root root 26 Feb 14 2019 2b349938.0 β AffirmTrust_Commercial.pem
lrwxrwxrwx 1 root root 18 Feb 14 2019 2e5ac55d.0 β DST_Root_CA_X3.pem
lrwxrwxrwx 1 root root 59 Feb 14 2019 32888f65.0 β Hellenic_Academic_and_Research_Institutions_RootCA_2015.pem
lrwxrwxrwx 1 root root 10 Feb 14 2019 349f2832.0 β EC-ACC.pem
lrwxrwxrwx 1 root root 27 Feb 14 2019 3513523f.0 β DigiCert_Global_Root_CA.pem
lrwxrwxrwx 1 root root 61 Feb 14 2019 3bde41ac.0 β Autoridad_de_Certificacion_Firmaprofesional_CIF_A62634068.pem
lrwxrwxrwx 1 root root 26 Feb 14 2019 3e44d2f7.0 β TrustCor_RootCert_CA-2.pem
lrwxrwxrwx 1 root root 27 Feb 14 2019 3e45d192.0 β Hongkong_Post_Root_CA_1.pem
lrwxrwxrwx 1 root root 45 Feb 24 13:09 3fb36b73.0 β NAVER_Global_Root_Certification_Authority.pem
lrwxrwxrwx 1 root root 31 Feb 14 2019 40193066.0 β Certum_Trusted_Network_CA_2.pem
lrwxrwxrwx 1 root root 16 Feb 14 2019 4042bcee.0 β ISRG_Root_X1.pem
lrwxrwxrwx 1 root root 34 Feb 14 2019 40547a79.0 β COMODO_Certification_Authority.pem
lrwxrwxrwx 1 root root 23 Feb 24 13:09 406c9bb1.0 β emSign_Root_CA -C1.pem
lrwxrwxrwx 1 root root 43 Feb 14 2019 4304c5e5.0 β Network_Solutions_Certificate_Authority.pem
lrwxrwxrwx 1 root root 29 Feb 14 2019 48bec511.0 β Certum_Trusted_Network_CA.pem
lrwxrwxrwx 1 root root 27 Feb 14 2019 4a6481c9.0 β GlobalSign_Root_CA -R2.pem
lrwxrwxrwx 1 root root 27 Feb 24 13:09 4b718d9b.0 β emSign_ECC_Root_CA -C3.pem
lrwxrwxrwx 1 root root 45 Feb 14 2019 4bfab552.0 β Starfield_Root_Certificate_Authority -G2.pem
lrwxrwxrwx 1 root root 26 Feb 14 2019 4f316efb.0 β SwissSign_Gold_CA -G2.pem
lrwxrwxrwx 1 root root 35 Feb 14 2019 5273a94c.0 β E-Tugra_Certification_Authority.pem
lrwxrwxrwx 1 root root 32 Feb 14 2019 5443e9e3.0 β T-TeleSec_GlobalRoot_Class_3.pem
lrwxrwxrwx 1 root root 27 Feb 14 2019 54657681.0 β Buypass_Class_2_Root_CA.pem
lrwxrwxrwx 1 root root 28 Feb 14 2019 57bcb2da.0 β SwissSign_Silver_CA -G2.pem
lrwxrwxrwx 1 root root 38 Feb 14 2019 5a4d6896.0 β Staat_der_Nederlanden_Root_CA -G3.pem
lrwxrwxrwx 1 root root 22 Feb 14 2019 5ad8a5d6.0 β GlobalSign_Root_CA.pem
lrwxrwxrwx 1 root root 26 Feb 14 2019 5cd81ad7.0 β TeliaSonera_Root_CA_v1.pem
lrwxrwxrwx 1 root root 26 Feb 14 2019 5d3033c5.0 β TrustCor_RootCert_CA-1.pem
lrwxrwxrwx 1 root root 45 Feb 24 13:09 5e98733a.0 β Entrust_Root_Certification_Authority -G4.pem
lrwxrwxrwx 1 root root 23 Feb 14 2019 5f15c80c.0 β TWCA_Global_Root_CA.pem
lrwxrwxrwx 1 root root 23 Feb 24 13:09 5f618aec.0 β certSIGN_Root_CA_G2.pem
lrwxrwxrwx 1 root root 27 Feb 14 2019 607986c7.0 β DigiCert_Global_Root_G2.pem
lrwxrwxrwx 1 root root 15 Feb 24 13:09 626dceaf.0 β GTS_Root_R2.pem
lrwxrwxrwx 1 root root 29 Feb 14 2019 653b494a.0 β Baltimore_CyberTrust_Root.pem
lrwxrwxrwx 1 root root 27 Feb 24 13:09 68dd7389.0 β Hongkong_Post_Root_CA_3.pem
lrwxrwxrwx 1 root root 40 Feb 14 2019 6b99d060.0 β Entrust_Root_Certification_Authority.pem
lrwxrwxrwx 1 root root 20 Feb 14 2019 6d41d539.0 β Amazon_Root_CA_2.pem
lrwxrwxrwx 1 root root 44 Feb 14 2019 6fa5da56.0 β SSL.com_Root_Certification_Authority_RSA.pem
lrwxrwxrwx 1 root root 24 Feb 14 2019 706f604c.0 β XRamp_Global_CA_Root.pem
lrwxrwxrwx 1 root root 25 Feb 14 2019 749e9e03.0 β QuoVadis_Root_CA_1_G3.pem
lrwxrwxrwx 1 root root 28 Feb 14 2019 75d1b2ed.0 β DigiCert_Trusted_Root_G4.pem
lrwxrwxrwx 1 root root 26 Feb 14 2019 76cb8f92.0 β Cybertrust_Global_Root.pem
lrwxrwxrwx 1 root root 22 Feb 14 2019 76faf6c0.0 β QuoVadis_Root_CA_3.pem
lrwxrwxrwx 1 root root 63 Feb 14 2019 7719f463.0 β Hellenic_Academic_and_Research_Institutions_ECC_RootCA_2015.pem
lrwxrwxrwx 1 root root 35 Feb 24 13:09 773e07ad.0 β OISTE_WISeKey_Global_Root_GC_CA.pem
lrwxrwxrwx 1 root root 18 Feb 14 2019 7aaf71c0.0 β TrustCor_ECA-1.pem
lrwxrwxrwx 1 root root 31 Feb 14 2019 7f3d5d1d.0 β DigiCert_Assured_ID_Root_G3.pem
lrwxrwxrwx 1 root root 34 Feb 14 2019 8160b96c.0 β Microsec_e-Szigno_Root_CA_2009.pem
lrwxrwxrwx 1 root root 24 Feb 24 13:09 82578957.0 β passbolt_certificate.crt
lrwxrwxrwx 1 root root 20 Feb 14 2019 8cb5ee0f.0 β Amazon_Root_CA_3.pem
lrwxrwxrwx 1 root root 20 Feb 14 2019 8d86cdd1.0 β certSIGN_ROOT_CA.pem
lrwxrwxrwx 1 root root 49 Feb 24 13:09 8d89cda1.0 β Microsoft_ECC_Root_Certificate_Authority_2017.pem
lrwxrwxrwx 1 root root 34 Feb 14 2019 930ac5d2.0 β Actalis_Authentication_Root_CA.pem
lrwxrwxrwx 1 root root 26 Feb 14 2019 93bc0acc.0 β AffirmTrust_Networking.pem
lrwxrwxrwx 1 root root 48 Feb 14 2019 988a38cb.0 β 'NetLock_Arany =Class_Gold=FΕtanΓΊsΓtvΓ‘ny.pemβ
lrwxrwxrwx 1 root root 53 Feb 24 13:09 9b5697b0.0 β Trustwave_Global_ECC_P256_Certification_Authority.pem
lrwxrwxrwx 1 root root 26 Feb 14 2019 9c2e7d30.0 β Sonera_Class_2_Root_CA.pem
lrwxrwxrwx 1 root root 27 Feb 14 2019 9c8dfbd4.0 β AffirmTrust_Premium_ECC.pem
lrwxrwxrwx 1 root root 31 Feb 14 2019 9d04f354.0 β DigiCert_Assured_ID_Root_G2.pem
lrwxrwxrwx 1 root root 15 Feb 24 13:09 a3418fda.0 β GTS_Root_R4.pem
lrwxrwxrwx 1 root root 13 Feb 14 2019 a94d09e5.0 β ACCVRAIZ1.pem
lrwxrwxrwx 1 root root 48 Feb 14 2019 ACCVRAIZ1.pem β /usr/share/ca-certificates/mozilla/ACCVRAIZ1.crt
lrwxrwxrwx 1 root root 55 Feb 14 2019 AC_RAIZ_FNMT-RCM.pem β /usr/share/ca-certificates/mozilla/AC_RAIZ_FNMT-RCM.crt
lrwxrwxrwx 1 root root 69 Feb 14 2019 Actalis_Authentication_Root_CA.pem β /usr/share/ca-certificates/mozilla/Actalis_Authentication_Root_CA.crt
lrwxrwxrwx 1 root root 45 Feb 14 2019 aee5f10d.0 β Entrust.net_Premium_2048_Secure_Server_CA.pem
lrwxrwxrwx 1 root root 61 Feb 14 2019 AffirmTrust_Commercial.pem β /usr/share/ca-certificates/mozilla/AffirmTrust_Commercial.crt
lrwxrwxrwx 1 root root 61 Feb 14 2019 AffirmTrust_Networking.pem β /usr/share/ca-certificates/mozilla/AffirmTrust_Networking.crt
lrwxrwxrwx 1 root root 62 Feb 14 2019 AffirmTrust_Premium_ECC.pem β /usr/share/ca-certificates/mozilla/AffirmTrust_Premium_ECC.crt
lrwxrwxrwx 1 root root 58 Feb 14 2019 AffirmTrust_Premium.pem β /usr/share/ca-certificates/mozilla/AffirmTrust_Premium.crt
lrwxrwxrwx 1 root root 55 Feb 14 2019 Amazon_Root_CA_1.pem β /usr/share/ca-certificates/mozilla/Amazon_Root_CA_1.crt
lrwxrwxrwx 1 root root 55 Feb 14 2019 Amazon_Root_CA_2.pem β /usr/share/ca-certificates/mozilla/Amazon_Root_CA_2.crt
lrwxrwxrwx 1 root root 55 Feb 14 2019 Amazon_Root_CA_3.pem β /usr/share/ca-certificates/mozilla/Amazon_Root_CA_3.crt
lrwxrwxrwx 1 root root 55 Feb 14 2019 Amazon_Root_CA_4.pem β /usr/share/ca-certificates/mozilla/Amazon_Root_CA_4.crt
lrwxrwxrwx 1 root root 60 Feb 14 2019 Atos_TrustedRoot_2011.pem β /usr/share/ca-certificates/mozilla/Atos_TrustedRoot_2011.crt
lrwxrwxrwx 1 root root 96 Feb 14 2019 Autoridad_de_Certificacion_Firmaprofesional_CIF_A62634068.pem β /usr/share/ca-certificates/mozilla/Autoridad_de_Certificacion_Firmaprofesional_CIF_A62634068.crt
lrwxrwxrwx 1 root root 31 Feb 14 2019 b0e59380.0 β GlobalSign_ECC_Root_CA -R4.pem
lrwxrwxrwx 1 root root 31 Feb 14 2019 b1159c4c.0 β DigiCert_Assured_ID_Root_CA.pem
lrwxrwxrwx 1 root root 20 Feb 14 2019 b66938e9.0 β Secure_Global_CA.pem
lrwxrwxrwx 1 root root 23 Feb 14 2019 b727005e.0 β AffirmTrust_Premium.pem
lrwxrwxrwx 1 root root 37 Feb 14 2019 b7a5b843.0 β TWCA_Root_Certification_Authority.pem
lrwxrwxrwx 1 root root 64 Feb 14 2019 Baltimore_CyberTrust_Root.pem β /usr/share/ca-certificates/mozilla/Baltimore_CyberTrust_Root.crt
lrwxrwxrwx 1 root root 49 Feb 24 13:09 bf53fb88.0 β Microsoft_RSA_Root_Certificate_Authority_2017.pem
lrwxrwxrwx 1 root root 62 Feb 14 2019 Buypass_Class_2_Root_CA.pem β /usr/share/ca-certificates/mozilla/Buypass_Class_2_Root_CA.crt
lrwxrwxrwx 1 root root 62 Feb 14 2019 Buypass_Class_3_Root_CA.pem β /usr/share/ca-certificates/mozilla/Buypass_Class_3_Root_CA.crt
lrwxrwxrwx 1 root root 51 Feb 14 2019 c01cdfa2.0 β VeriSign_Universal_Root_Certification_Authority.pem
lrwxrwxrwx 1 root root 22 Feb 24 13:09 c01eb047.0 β UCA_Global_G2_Root.pem
lrwxrwxrwx 1 root root 34 Feb 14 2019 c28a8a30.0 β D-TRUST_Root_Class_3_CA_2_2009.pem
lrwxrwxrwx 1 root root 36 Feb 14 2019 c47d9980.0 β Chambers_of_Commerce_Root -2008.pem
lrwxrwxrwx 1 root root 37 Feb 14 2019 ca6e4ad9.0 β ePKI_Root_Certification_Authority.pem
-rw-rβr-- 1 root root 200313 Feb 25 08:49 ca-certificates.crt
lrwxrwxrwx 1 root root 55 Feb 14 2019 CA_Disig_Root_R2.pem β /usr/share/ca-certificates/mozilla/CA_Disig_Root_R2.crt
lrwxrwxrwx 1 root root 44 Feb 14 2019 cbf06781.0 β Go_Daddy_Root_Certificate_Authority -G2.pem
lrwxrwxrwx 1 root root 14 Feb 14 2019 cc450945.0 β Izenpe.com.pem
lrwxrwxrwx 1 root root 34 Feb 14 2019 cd58d51e.0 β Security_Communication_RootCA2.pem
lrwxrwxrwx 1 root root 20 Feb 14 2019 cd8c0d63.0 β AC_RAIZ_FNMT-RCM.pem
lrwxrwxrwx 1 root root 20 Feb 14 2019 ce5e74ef.0 β Amazon_Root_CA_1.pem
lrwxrwxrwx 1 root root 47 Feb 14 2019 Certigna.pem β /usr/share/ca-certificates/mozilla/Certigna.crt
lrwxrwxrwx 1 root root 55 Feb 24 13:09 Certigna_Root_CA.pem β /usr/share/ca-certificates/mozilla/Certigna_Root_CA.crt
lrwxrwxrwx 1 root root 58 Feb 24 13:09 certSIGN_Root_CA_G2.pem β /usr/share/ca-certificates/mozilla/certSIGN_Root_CA_G2.crt
lrwxrwxrwx 1 root root 55 Feb 14 2019 certSIGN_ROOT_CA.pem β /usr/share/ca-certificates/mozilla/certSIGN_ROOT_CA.crt
lrwxrwxrwx 1 root root 66 Feb 14 2019 Certum_Trusted_Network_CA_2.pem β /usr/share/ca-certificates/mozilla/Certum_Trusted_Network_CA_2.crt
lrwxrwxrwx 1 root root 64 Feb 14 2019 Certum_Trusted_Network_CA.pem β /usr/share/ca-certificates/mozilla/Certum_Trusted_Network_CA.crt
lrwxrwxrwx 1 root root 51 Feb 14 2019 CFCA_EV_ROOT.pem β /usr/share/ca-certificates/mozilla/CFCA_EV_ROOT.crt
lrwxrwxrwx 1 root root 71 Feb 14 2019 Chambers_of_Commerce_Root -2008.pem β /usr/share/ca-certificates/mozilla/Chambers_of_Commerce_Root -2008.crt
lrwxrwxrwx 1 root root 63 Feb 14 2019 Comodo_AAA_Services_root.pem β /usr/share/ca-certificates/mozilla/Comodo_AAA_Services_root.crt
lrwxrwxrwx 1 root root 69 Feb 14 2019 COMODO_Certification_Authority.pem β /usr/share/ca-certificates/mozilla/COMODO_Certification_Authority.crt
lrwxrwxrwx 1 root root 73 Feb 14 2019 COMODO_ECC_Certification_Authority.pem β /usr/share/ca-certificates/mozilla/COMODO_ECC_Certification_Authority.crt
lrwxrwxrwx 1 root root 73 Feb 14 2019 COMODO_RSA_Certification_Authority.pem β /usr/share/ca-certificates/mozilla/COMODO_RSA_Certification_Authority.crt
lrwxrwxrwx 1 root root 61 Feb 14 2019 Cybertrust_Global_Root.pem β /usr/share/ca-certificates/mozilla/Cybertrust_Global_Root.crt
lrwxrwxrwx 1 root root 37 Feb 14 2019 d4dae3dd.0 β D-TRUST_Root_Class_3_CA_2_EV_2009.pem
lrwxrwxrwx 1 root root 38 Feb 14 2019 d6325660.0 β COMODO_RSA_Certification_Authority.pem
lrwxrwxrwx 1 root root 22 Feb 14 2019 d7e8dc79.0 β QuoVadis_Root_CA_2.pem
lrwxrwxrwx 1 root root 23 Feb 14 2019 d853d49e.0 β Trustis_FPS_Root_CA.pem
lrwxrwxrwx 1 root root 53 Feb 24 13:09 d887a5bb.0 β Trustwave_Global_ECC_P384_Certification_Authority.pem
lrwxrwxrwx 1 root root 27 Feb 24 13:09 dc4d6a89.0 β GlobalSign_Root_CA -R6.pem
lrwxrwxrwx 1 root root 27 Feb 14 2019 dd8e9d41.0 β DigiCert_Global_Root_G3.pem
lrwxrwxrwx 1 root root 20 Feb 14 2019 de6d66f3.0 β Amazon_Root_CA_4.pem
lrwxrwxrwx 1 root root 66 Feb 14 2019 DigiCert_Assured_ID_Root_CA.pem β /usr/share/ca-certificates/mozilla/DigiCert_Assured_ID_Root_CA.crt
lrwxrwxrwx 1 root root 66 Feb 14 2019 DigiCert_Assured_ID_Root_G2.pem β /usr/share/ca-certificates/mozilla/DigiCert_Assured_ID_Root_G2.crt
lrwxrwxrwx 1 root root 66 Feb 14 2019 DigiCert_Assured_ID_Root_G3.pem β /usr/share/ca-certificates/mozilla/DigiCert_Assured_ID_Root_G3.crt
lrwxrwxrwx 1 root root 62 Feb 14 2019 DigiCert_Global_Root_CA.pem β /usr/share/ca-certificates/mozilla/DigiCert_Global_Root_CA.crt
lrwxrwxrwx 1 root root 62 Feb 14 2019 DigiCert_Global_Root_G2.pem β /usr/share/ca-certificates/mozilla/DigiCert_Global_Root_G2.crt
lrwxrwxrwx 1 root root 62 Feb 14 2019 DigiCert_Global_Root_G3.pem β /usr/share/ca-certificates/mozilla/DigiCert_Global_Root_G3.crt
lrwxrwxrwx 1 root root 73 Feb 14 2019 DigiCert_High_Assurance_EV_Root_CA.pem β /usr/share/ca-certificates/mozilla/DigiCert_High_Assurance_EV_Root_CA.crt
lrwxrwxrwx 1 root root 63 Feb 14 2019 DigiCert_Trusted_Root_G4.pem β /usr/share/ca-certificates/mozilla/DigiCert_Trusted_Root_G4.crt
lrwxrwxrwx 1 root root 53 Feb 14 2019 DST_Root_CA_X3.pem β /usr/share/ca-certificates/mozilla/DST_Root_CA_X3.crt
lrwxrwxrwx 1 root root 69 Feb 14 2019 D-TRUST_Root_Class_3_CA_2_2009.pem β /usr/share/ca-certificates/mozilla/D-TRUST_Root_Class_3_CA_2_2009.crt
lrwxrwxrwx 1 root root 72 Feb 14 2019 D-TRUST_Root_Class_3_CA_2_EV_2009.pem β /usr/share/ca-certificates/mozilla/D-TRUST_Root_Class_3_CA_2_EV_2009.crt
lrwxrwxrwx 1 root root 12 Feb 14 2019 e113c810.0 β Certigna.pem
lrwxrwxrwx 1 root root 25 Feb 14 2019 e18bfb83.0 β QuoVadis_Root_CA_3_G3.pem
lrwxrwxrwx 1 root root 25 Feb 14 2019 e36a6752.0 β Atos_TrustedRoot_2011.pem
lrwxrwxrwx 1 root root 35 Feb 14 2019 e73d606e.0 β OISTE_WISeKey_Global_Root_GB_CA.pem
lrwxrwxrwx 1 root root 25 Feb 24 13:09 e868b802.0 β e-Szigno_Root_CA_2017.pem
lrwxrwxrwx 1 root root 27 Feb 14 2019 e8de2f56.0 β Buypass_Class_3_Root_CA.pem
lrwxrwxrwx 1 root root 45 Feb 14 2019 EC-ACC.pem β /usr/share/ca-certificates/mozilla/EC-ACC.crt
lrwxrwxrwx 1 root root 28 Feb 14 2019 ee64a828.0 β Comodo_AAA_Services_root.pem
lrwxrwxrwx 1 root root 38 Feb 14 2019 eed8c118.0 β COMODO_ECC_Certification_Authority.pem
lrwxrwxrwx 1 root root 34 Feb 14 2019 ef954a4e.0 β IdenTrust_Commercial_Root_CA_1.pem
lrwxrwxrwx 1 root root 62 Feb 24 13:09 emSign_ECC_Root_CA -C3.pem β /usr/share/ca-certificates/mozilla/emSign_ECC_Root_CA -C3.crt
lrwxrwxrwx 1 root root 62 Feb 24 13:09 emSign_ECC_Root_CA -G3.pem β /usr/share/ca-certificates/mozilla/emSign_ECC_Root_CA -G3.crt
lrwxrwxrwx 1 root root 58 Feb 24 13:09 emSign_Root_CA -C1.pem β /usr/share/ca-certificates/mozilla/emSign_Root_CA -C1.crt
lrwxrwxrwx 1 root root 58 Feb 24 13:09 emSign_Root_CA -G1.pem β /usr/share/ca-certificates/mozilla/emSign_Root_CA -G1.crt
lrwxrwxrwx 1 root root 80 Feb 14 2019 Entrust.net_Premium_2048_Secure_Server_CA.pem β /usr/share/ca-certificates/mozilla/Entrust.net_Premium_2048_Secure_Server_CA.crt
lrwxrwxrwx 1 root root 81 Feb 14 2019 Entrust_Root_Certification_Authority -EC1.pem β /usr/share/ca-certificates/mozilla/Entrust_Root_Certification_Authority -EC1.crt
lrwxrwxrwx 1 root root 80 Feb 14 2019 Entrust_Root_Certification_Authority -G2.pem β /usr/share/ca-certificates/mozilla/Entrust_Root_Certification_Authority -G2.crt
lrwxrwxrwx 1 root root 80 Feb 24 13:09 Entrust_Root_Certification_Authority -G4.pem β /usr/share/ca-certificates/mozilla/Entrust_Root_Certification_Authority -G4.crt
lrwxrwxrwx 1 root root 75 Feb 14 2019 Entrust_Root_Certification_Authority.pem β /usr/share/ca-certificates/mozilla/Entrust_Root_Certification_Authority.crt
lrwxrwxrwx 1 root root 72 Feb 14 2019 ePKI_Root_Certification_Authority.pem β /usr/share/ca-certificates/mozilla/ePKI_Root_Certification_Authority.crt
lrwxrwxrwx 1 root root 60 Feb 24 13:09 e-Szigno_Root_CA_2017.pem β /usr/share/ca-certificates/mozilla/e-Szigno_Root_CA_2017.crt
lrwxrwxrwx 1 root root 70 Feb 14 2019 E-Tugra_Certification_Authority.pem β /usr/share/ca-certificates/mozilla/E-Tugra_Certification_Authority.crt
lrwxrwxrwx 1 root root 23 Feb 14 2019 f081611a.0 β Go_Daddy_Class_2_CA.pem
lrwxrwxrwx 1 root root 47 Feb 14 2019 f0c70a8d.0 β SSL.com_EV_Root_Certification_Authority_ECC.pem
lrwxrwxrwx 1 root root 44 Feb 24 13:09 f249de83.0 β Trustwave_Global_Certification_Authority.pem
lrwxrwxrwx 1 root root 41 Feb 14 2019 f30dd6ad.0 β USERTrust_ECC_Certification_Authority.pem
lrwxrwxrwx 1 root root 34 Feb 14 2019 f3377b1b.0 β Security_Communication_Root_CA.pem
lrwxrwxrwx 1 root root 24 Feb 14 2019 f387163d.0 β Starfield_Class_2_CA.pem
lrwxrwxrwx 1 root root 18 Feb 14 2019 f39fc864.0 β SecureTrust_CA.pem
lrwxrwxrwx 1 root root 20 Feb 24 13:09 f51bb24c.0 β Certigna_Root_CA.pem
lrwxrwxrwx 1 root root 41 Feb 14 2019 fc5a8f99.0 β USERTrust_RSA_Certification_Authority.pem
lrwxrwxrwx 1 root root 19 Feb 14 2019 fe8a2cd8.0 β SZAFIR_ROOT_CA2.pem
lrwxrwxrwx 1 root root 49 Feb 14 2019 ff34af3f.0 β TUBITAK_Kamu_SM_SSL_Kok_Sertifikasi -Surum_1.pem
lrwxrwxrwx 1 root root 61 Feb 14 2019 GDCA_TrustAUTH_R5_ROOT.pem β /usr/share/ca-certificates/mozilla/GDCA_TrustAUTH_R5_ROOT.crt
lrwxrwxrwx 1 root root 84 Feb 14 2019 GeoTrust_Primary_Certification_Authority -G2.pem β /usr/share/ca-certificates/mozilla/GeoTrust_Primary_Certification_Authority -G2.crt
lrwxrwxrwx 1 root root 69 Feb 14 2019 Global_Chambersign_Root -2008.pem β /usr/share/ca-certificates/mozilla/Global_Chambersign_Root -2008.crt
lrwxrwxrwx 1 root root 66 Feb 14 2019 GlobalSign_ECC_Root_CA -R4.pem β /usr/share/ca-certificates/mozilla/GlobalSign_ECC_Root_CA -R4.crt
lrwxrwxrwx 1 root root 66 Feb 14 2019 GlobalSign_ECC_Root_CA -R5.pem β /usr/share/ca-certificates/mozilla/GlobalSign_ECC_Root_CA -R5.crt
lrwxrwxrwx 1 root root 57 Feb 14 2019 GlobalSign_Root_CA.pem β /usr/share/ca-certificates/mozilla/GlobalSign_Root_CA.crt
lrwxrwxrwx 1 root root 62 Feb 14 2019 GlobalSign_Root_CA -R2.pem β /usr/share/ca-certificates/mozilla/GlobalSign_Root_CA -R2.crt
lrwxrwxrwx 1 root root 62 Feb 14 2019 GlobalSign_Root_CA -R3.pem β /usr/share/ca-certificates/mozilla/GlobalSign_Root_CA -R3.crt
lrwxrwxrwx 1 root root 62 Feb 24 13:09 GlobalSign_Root_CA -R6.pem β /usr/share/ca-certificates/mozilla/GlobalSign_Root_CA -R6.crt
lrwxrwxrwx 1 root root 58 Feb 14 2019 Go_Daddy_Class_2_CA.pem β /usr/share/ca-certificates/mozilla/Go_Daddy_Class_2_CA.crt
lrwxrwxrwx 1 root root 79 Feb 14 2019 Go_Daddy_Root_Certificate_Authority -G2.pem β /usr/share/ca-certificates/mozilla/Go_Daddy_Root_Certificate_Authority -G2.crt
lrwxrwxrwx 1 root root 50 Feb 24 13:09 GTS_Root_R1.pem β /usr/share/ca-certificates/mozilla/GTS_Root_R1.crt
lrwxrwxrwx 1 root root 50 Feb 24 13:09 GTS_Root_R2.pem β /usr/share/ca-certificates/mozilla/GTS_Root_R2.crt
lrwxrwxrwx 1 root root 50 Feb 24 13:09 GTS_Root_R3.pem β /usr/share/ca-certificates/mozilla/GTS_Root_R3.crt
lrwxrwxrwx 1 root root 50 Feb 24 13:09 GTS_Root_R4.pem β /usr/share/ca-certificates/mozilla/GTS_Root_R4.crt
lrwxrwxrwx 1 root root 98 Feb 14 2019 Hellenic_Academic_and_Research_Institutions_ECC_RootCA_2015.pem β /usr/share/ca-certificates/mozilla/Hellenic_Academic_and_Research_Institutions_ECC_RootCA_2015.crt
lrwxrwxrwx 1 root root 94 Feb 14 2019 Hellenic_Academic_and_Research_Institutions_RootCA_2011.pem β /usr/share/ca-certificates/mozilla/Hellenic_Academic_and_Research_Institutions_RootCA_2011.crt
lrwxrwxrwx 1 root root 94 Feb 14 2019 Hellenic_Academic_and_Research_Institutions_RootCA_2015.pem β /usr/share/ca-certificates/mozilla/Hellenic_Academic_and_Research_Institutions_RootCA_2015.crt
lrwxrwxrwx 1 root root 62 Feb 14 2019 Hongkong_Post_Root_CA_1.pem β /usr/share/ca-certificates/mozilla/Hongkong_Post_Root_CA_1.crt
lrwxrwxrwx 1 root root 62 Feb 24 13:09 Hongkong_Post_Root_CA_3.pem β /usr/share/ca-certificates/mozilla/Hongkong_Post_Root_CA_3.crt
lrwxrwxrwx 1 root root 69 Feb 14 2019 IdenTrust_Commercial_Root_CA_1.pem β /usr/share/ca-certificates/mozilla/IdenTrust_Commercial_Root_CA_1.crt
lrwxrwxrwx 1 root root 72 Feb 14 2019 IdenTrust_Public_Sector_Root_CA_1.pem β /usr/share/ca-certificates/mozilla/IdenTrust_Public_Sector_Root_CA_1.crt
lrwxrwxrwx 1 root root 51 Feb 14 2019 ISRG_Root_X1.pem β /usr/share/ca-certificates/mozilla/ISRG_Root_X1.crt
lrwxrwxrwx 1 root root 49 Feb 14 2019 Izenpe.com.pem β /usr/share/ca-certificates/mozilla/Izenpe.com.crt
-rw-rβr-- 1 root root 0 Feb 25 10:43 lsout
lrwxrwxrwx 1 root root 69 Feb 14 2019 Microsec_e-Szigno_Root_CA_2009.pem β /usr/share/ca-certificates/mozilla/Microsec_e-Szigno_Root_CA_2009.crt
lrwxrwxrwx 1 root root 84 Feb 24 13:09 Microsoft_ECC_Root_Certificate_Authority_2017.pem β /usr/share/ca-certificates/mozilla/Microsoft_ECC_Root_Certificate_Authority_2017.crt
lrwxrwxrwx 1 root root 84 Feb 24 13:09 Microsoft_RSA_Root_Certificate_Authority_2017.pem β /usr/share/ca-certificates/mozilla/Microsoft_RSA_Root_Certificate_Authority_2017.crt
lrwxrwxrwx 1 root root 80 Feb 24 13:09 NAVER_Global_Root_Certification_Authority.pem β /usr/share/ca-certificates/mozilla/NAVER_Global_Root_Certification_Authority.crt
lrwxrwxrwx 1 root root 83 Feb 14 2019 'NetLock_Arany =Class_Gold=FΕtanΓΊsΓtvΓ‘ny.pemβ β '/usr/share/ca-certificates/mozilla/NetLock_Arany =Class_Gold=FΕtanΓΊsΓtvΓ‘ny.crtβ
lrwxrwxrwx 1 root root 78 Feb 14 2019 Network_Solutions_Certificate_Authority.pem β /usr/share/ca-certificates/mozilla/Network_Solutions_Certificate_Authority.crt
lrwxrwxrwx 1 root root 70 Feb 14 2019 OISTE_WISeKey_Global_Root_GB_CA.pem β /usr/share/ca-certificates/mozilla/OISTE_WISeKey_Global_Root_GB_CA.crt
lrwxrwxrwx 1 root root 70 Feb 24 13:09 OISTE_WISeKey_Global_Root_GC_CA.pem β /usr/share/ca-certificates/mozilla/OISTE_WISeKey_Global_Root_GC_CA.crt
-rw-rβr-- 1 root root 1480 Jul 16 2019 passbolt_certificate.crt
-rw------- 1 root root 1708 Jul 16 2019 passbolt_private.key
lrwxrwxrwx 1 root root 60 Feb 14 2019 QuoVadis_Root_CA_1_G3.pem β /usr/share/ca-certificates/mozilla/QuoVadis_Root_CA_1_G3.crt
lrwxrwxrwx 1 root root 60 Feb 14 2019 QuoVadis_Root_CA_2_G3.pem β /usr/share/ca-certificates/mozilla/QuoVadis_Root_CA_2_G3.crt
lrwxrwxrwx 1 root root 57 Feb 14 2019 QuoVadis_Root_CA_2.pem β /usr/share/ca-certificates/mozilla/QuoVadis_Root_CA_2.crt
lrwxrwxrwx 1 root root 60 Feb 14 2019 QuoVadis_Root_CA_3_G3.pem β /usr/share/ca-certificates/mozilla/QuoVadis_Root_CA_3_G3.crt
lrwxrwxrwx 1 root root 57 Feb 14 2019 QuoVadis_Root_CA_3.pem β /usr/share/ca-certificates/mozilla/QuoVadis_Root_CA_3.crt
lrwxrwxrwx 1 root root 55 Feb 14 2019 QuoVadis_Root_CA.pem β /usr/share/ca-certificates/mozilla/QuoVadis_Root_CA.crt
lrwxrwxrwx 1 root root 55 Feb 14 2019 Secure_Global_CA.pem β /usr/share/ca-certificates/mozilla/Secure_Global_CA.crt
lrwxrwxrwx 1 root root 58 Feb 14 2019 SecureSign_RootCA11.pem β /usr/share/ca-certificates/mozilla/SecureSign_RootCA11.crt
lrwxrwxrwx 1 root root 53 Feb 14 2019 SecureTrust_CA.pem β /usr/share/ca-certificates/mozilla/SecureTrust_CA.crt
lrwxrwxrwx 1 root root 69 Feb 14 2019 Security_Communication_RootCA2.pem β /usr/share/ca-certificates/mozilla/Security_Communication_RootCA2.crt
lrwxrwxrwx 1 root root 69 Feb 14 2019 Security_Communication_Root_CA.pem β /usr/share/ca-certificates/mozilla/Security_Communication_Root_CA.crt
lrwxrwxrwx 1 root root 61 Feb 14 2019 Sonera_Class_2_Root_CA.pem β /usr/share/ca-certificates/mozilla/Sonera_Class_2_Root_CA.crt
-rw-rβr-- 1 root root 1127 Aug 5 2019 ssl-cert-snakeoil.pem
lrwxrwxrwx 1 root root 82 Feb 14 2019 SSL.com_EV_Root_Certification_Authority_ECC.pem β /usr/share/ca-certificates/mozilla/SSL.com_EV_Root_Certification_Authority_ECC.crt
lrwxrwxrwx 1 root root 85 Feb 14 2019 SSL.com_EV_Root_Certification_Authority_RSA_R2.pem β /usr/share/ca-certificates/mozilla/SSL.com_EV_Root_Certification_Authority_RSA_R2.crt
lrwxrwxrwx 1 root root 79 Feb 14 2019 SSL.com_Root_Certification_Authority_ECC.pem β /usr/share/ca-certificates/mozilla/SSL.com_Root_Certification_Authority_ECC.crt
lrwxrwxrwx 1 root root 79 Feb 14 2019 SSL.com_Root_Certification_Authority_RSA.pem β /usr/share/ca-certificates/mozilla/SSL.com_Root_Certification_Authority_RSA.crt
lrwxrwxrwx 1 root root 71 Feb 14 2019 Staat_der_Nederlanden_EV_Root_CA.pem β /usr/share/ca-certificates/mozilla/Staat_der_Nederlanden_EV_Root_CA.crt
lrwxrwxrwx 1 root root 73 Feb 14 2019 Staat_der_Nederlanden_Root_CA -G3.pem β /usr/share/ca-certificates/mozilla/Staat_der_Nederlanden_Root_CA -G3.crt
lrwxrwxrwx 1 root root 59 Feb 14 2019 Starfield_Class_2_CA.pem β /usr/share/ca-certificates/mozilla/Starfield_Class_2_CA.crt
lrwxrwxrwx 1 root root 80 Feb 14 2019 Starfield_Root_Certificate_Authority -G2.pem β /usr/share/ca-certificates/mozilla/Starfield_Root_Certificate_Authority -G2.crt
lrwxrwxrwx 1 root root 89 Feb 14 2019 Starfield_Services_Root_Certificate_Authority -G2.pem β /usr/share/ca-certificates/mozilla/Starfield_Services_Root_Certificate_Authority -G2.crt
lrwxrwxrwx 1 root root 61 Feb 14 2019 SwissSign_Gold_CA -G2.pem β /usr/share/ca-certificates/mozilla/SwissSign_Gold_CA -G2.crt
lrwxrwxrwx 1 root root 63 Feb 14 2019 SwissSign_Silver_CA -G2.pem β /usr/share/ca-certificates/mozilla/SwissSign_Silver_CA -G2.crt
lrwxrwxrwx 1 root root 54 Feb 14 2019 SZAFIR_ROOT_CA2.pem β /usr/share/ca-certificates/mozilla/SZAFIR_ROOT_CA2.crt
lrwxrwxrwx 1 root root 61 Feb 14 2019 TeliaSonera_Root_CA_v1.pem β /usr/share/ca-certificates/mozilla/TeliaSonera_Root_CA_v1.crt
lrwxrwxrwx 1 root root 53 Feb 14 2019 TrustCor_ECA-1.pem β /usr/share/ca-certificates/mozilla/TrustCor_ECA-1.crt
lrwxrwxrwx 1 root root 61 Feb 14 2019 TrustCor_RootCert_CA-1.pem β /usr/share/ca-certificates/mozilla/TrustCor_RootCert_CA-1.crt
lrwxrwxrwx 1 root root 61 Feb 14 2019 TrustCor_RootCert_CA-2.pem β /usr/share/ca-certificates/mozilla/TrustCor_RootCert_CA-2.crt
lrwxrwxrwx 1 root root 58 Feb 14 2019 Trustis_FPS_Root_CA.pem β /usr/share/ca-certificates/mozilla/Trustis_FPS_Root_CA.crt
lrwxrwxrwx 1 root root 79 Feb 24 13:09 Trustwave_Global_Certification_Authority.pem β /usr/share/ca-certificates/mozilla/Trustwave_Global_Certification_Authority.crt
lrwxrwxrwx 1 root root 88 Feb 24 13:09 Trustwave_Global_ECC_P256_Certification_Authority.pem β /usr/share/ca-certificates/mozilla/Trustwave_Global_ECC_P256_Certification_Authority.crt
lrwxrwxrwx 1 root root 88 Feb 24 13:09 Trustwave_Global_ECC_P384_Certification_Authority.pem β /usr/share/ca-certificates/mozilla/Trustwave_Global_ECC_P384_Certification_Authority.crt
lrwxrwxrwx 1 root root 67 Feb 14 2019 T-TeleSec_GlobalRoot_Class_2.pem β /usr/share/ca-certificates/mozilla/T-TeleSec_GlobalRoot_Class_2.crt
lrwxrwxrwx 1 root root 67 Feb 14 2019 T-TeleSec_GlobalRoot_Class_3.pem β /usr/share/ca-certificates/mozilla/T-TeleSec_GlobalRoot_Class_3.crt
lrwxrwxrwx 1 root root 84 Feb 14 2019 TUBITAK_Kamu_SM_SSL_Kok_Sertifikasi -Surum_1.pem β /usr/share/ca-certificates/mozilla/TUBITAK_Kamu_SM_SSL_Kok_Sertifikasi -_Surum_1.crt
Symlink
#4
I rached max characters in my last message.
Here is the output of my health check
Warning Error: SplFileInfo::openFile(/home/vaultadmin/tmp/cache/persistent/myapp_cake_core_translations_default_en__u_s): failed to open stream: Permission denied in [/home/vaultadmin/vendor/cakephp/cakephp/src/Cache/Engine/FileEngine.php, line 406]
Warning Error: SplFileInfo::openFile(/home/vaultadmin/tmp/cache/persistent/myapp_cake_core_translations_cake_console_en__u_s): failed to open stream: Permission denied in [/home/vaultadmin/vendor/cakephp/cakephp/src/Cache/Engine/FileEngine.php, line 406]
/ / _ , / / / ./_ / /__/
Healthcheck shellβ¦Exception: SQLSTATE[HY000] [1045] Access denied for user ββ@βlocalhostβ (using password: NO) in [/home/vaultadmin/vendor/cakephp/cakephp/src/Database/Driver.php, line 92]
Also I do not have the file /etc/passbolt/nginx-ssl.conf so I could not verify the reference.
diego
February 25, 2021, 4:01pm
#5
Hi @Symlink
Something is off, the ubuntu package installation directory is /usr/share/php/passbolt and according with your message your logs are mentioning /hom/vaultadmin this should not be the behaviour.
Maybe your nginx settings are still pointing to your old installation directory?
Symlink
February 25, 2021, 4:07pm
#6
Hi @diego
I might be wrong but I am looking at /etc/nginx/sites-enabled and I see :
Which is fine right?
I might have messed up during Ubuntu upgrade 20.04 and selected keep nginx settings ? But I donβt quite see why the upgrade package wouldnβt change the configuration files to reflect the new setup.
Do I need to look at anything specific ?
Symlink
February 25, 2021, 4:37pm
#7
Hi @diego
I tried other steps.
Since I ran sudo -H -u www-data bash -c β./bin/cake passbolt healthcheckβ and you mentionned the folder seemed wrong.
I navitaged to /usr/share/php/passbolt/ instead to rerun the command. Here is the output :
[PASS] PHP version 7.4.3.
[PASS] Full base url is set to https://mac-svr-pr-vault.macco.local
[HELP] cURL Error (6) Could not resolve host: mac-svr-pr-vault.macco.local
[PASS] 25 tables found
[HELP] you can try:
[HELP] sudo su -s /bin/bash -c βgpg --home /var/lib/passbolt/.gnupg --import /etc/passbolt//gpg/serverkey_private.ascβ www-data
[FAIL] Could not connect to passbolt repository to check versions It is not possible check if your version is up to date.
6 error(s) found. Hang in there!
diego
February 25, 2021, 5:09pm
#8
The contents of /etc/nginx/sites-enabled/passbolt.conf is correct.
Iβm thinking if you left something in /etc/nginx/conf.d which is pointing to your old passbolt setup
Symlink
February 25, 2021, 5:21pm
#9
Hi @diego
The content of my conf.d folder in /etc/nginx is empty.
I do seem to have a trouble resolving since the Ubuntu 20.04 upgrade.
if I try to ping anything with itβs FQDN I get :
Temporary failure in name resolution
I tried to look at my netplan configuration :
ens192:
dhcp4: no
addresses:
- XXX.XXX.XXX.134/24
gateway4: XXX.XXX.XXX.254
nameservers:
addresses: [XXX.XXX.XXX.230, XXX.XXX.XXX.231]
and I couldnβt find anything wrong. Now of course I know there are spaces in yaml and when I apply the config with sudo netplan apply it doesnβt give me any configuration error.
I think Iβll have to restore my VM to 2.3 and leave it be I might lack the knowledge to succeed in upgrading.
garrett
February 25, 2021, 8:53pm
#10
@Symlink If you are now using certs for a domain that the old version did not use, you may need to note the domain name in /etc/hosts
so that the server knows its own domain:
127.0.0.1 yourdomain.com localhost
