Hi!
What can i do with a group that are not contain any user?
With an admin user can see group members, but cant add others, because the admin user are not a group manager.
BR,
Z
Hi!
BR,
Z
Hi @somogyi,
Only a group manager can add / remove users from a given group, even if you are passbolt admin.
From the users workspace, if you click on a group, you should be able to see its members with an admin right.
Hope this helps,
Hi @AnatomicJC,
We made changes with some user (delete, reactivate). After that some groups are empty. Can we manage this situation somehow, like in the database or any method?
BR,
Z
Did you deleted your users directly on your database ? It is not recommended as passbolt API take care of always have at least one manager for a group.
The only way I think is to delete then re-create the group. Are you able to do it from the web interface ?
