MFA fails randomly
Lately we’ve been experiencing issue with the mfa again, before it was timesyncing issue but we eliminated that and it was fine for a couple of months but now it’s happening again. After setting up mfa it works for some time then it starts failing collectively.
We use on prem passbolt installed on ubuntu 22.04 and chrony as a timesync client syncing with pool.ntp.org .
The time is synced and on point.
Restarting the server or chrony doesn’t solve the issue.
Any ideas where i should start looking?
Healthcheck:
/ / __ `/ / / __ / __ / / _/
/ _
//./_//__/
Healthcheck shell…
[PASS] PHP version 8.1.2-1ubuntu2.17.
[PASS] Full base url is set to ********
SMTP settings
[PASS] Using latest passbolt version (4.8.0).
[PASS] 49 tables found.
Directory Sync
[WARN] The endpoints for updating the users directory configurations are enabled.
[HELP] It is recommended to disable endpoints for updating the users directory configurations.
[HELP] Set the PASSBOLT_SECURITY_DIRECTORY_SYNC_ENDPOINTS_DISABLED environment variable to true.
[HELP] Or set passbolt.security.directorySync.endpointsDisabled to true in /etc/passbolt/passbolt.php.
SSO
[PASS] SSL certification validation for SSO instance is enabled.
Hello @matreicht,
Sometimes time synchronization issues are also related to the client iself.
Can you confirm that both the server and client are time synchronized? Also, which error do you have with MFA? We need some details in order to understand what could be happening
Hello antony,
The client and a server are both time synchronized and have the same time.
Error:
The server responds with invalid otp code and users cannot log in to their account unless mfa is disabled manually.
I saw that you were on ubuntu but have you enabled SELinux or AppArmor ?
After censoring the fullBaseUrl and so on, could you share the full output of the status report?
sudo su -s /bin/bash -c "/usr/share/php/passbolt/bin/status-report" www-data
This should contain the datacheck, cleanup dry run, server logs and the healthCheck that you already shared.
  • Also, do you see any errors on the browser extension logs console after reproducing the error?
  • Is it happening for all of your users?
Thanks :slight_smile:
No selinux or apparmor enabled, i can’t confirm the all users part since the 1 month for mfa runs out at different times for everyone, i received complaints about many users. Reseting the mfa fixes the issue for the user until it starts failing again. No errors in the browser extension logs.
Here’s the status report:
/ _
//./_//__/
Passbolt PRO 4.8.0
Cakephp 4.5.2
Linux t-passbolt 5.15.0-112-generic #122-Ubuntu SMP Thu May 23 07:48:21 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
PHP 8.1.2-1ubuntu2.17 (cli) (built: May 1 2024 10:10:07) (NTS)
mysql Ver 8.0.37-0ubuntu0.22.04.3 for Linux on x86_64 ((Ubuntu))
gpg (GnuPG) 2.2.27
libgcrypt 1.9.4
/ _
//./_//__/
[PASS] Full base url is set to ***********
SMTP settings
Directory Sync
SSO
/ _
//./_//__/
Cleanup shell (dry-run)
3 issues found in table Groups (with no members)
3 issues detected, please re-run without --dry-run to fix.
/ _
//./_//__/
Data check shell
[PASS] Can validate: 2328/2328
[PASS] Can validate: 0/0
[PASS] Can encrypt: 27/27
[PASS] Pass validation service checks: 27/27
[PASS] Entity data and armored key data matches: 27/27
[PASS] Is not expired: 27/27
[PASS] Is armored key format valid: 27/27
[PASS] Can validate: 9/9
[PASS] Can validate: 39/39
[PASS] Can validate: 1859/1859
[PASS] Can validate: 7816/7816
Hey,
I noticed something weird today, I checked the outgoing email logs and I saw that the time is wrong within passbolt, the email log stated that the email was sent out at 11:14:16 while the time according to the OS was 13:14:16. How come OS time and passbolt time differ?
Since it is exactly a 2 hour difference it looks like UTC vs your current time zone. Do you happen to be in a country that is currently in UTC+2?
Yes I am. It does look like time zone diff. Is there a separate setting within passbolt for time zones?
Hey, I searched the php coding of passbolt and have seen that the default timezone setting is UTC for , but don’t see where/if it is being overruled by the time settings of the OS (in previous versions it worked fine). I also edited the php.ini [Date] date.timezone parameter hoping it would be applied to passbolt unfortunately with no success. Any ideas what to try next?
For the email timezone we don’t currently have a way to really change this. We do have an internal ticket(PB-24267) as this has been requested a couple times. We initially went with UTC as the default time since it is usually easier for organizations operating in multiple timezones and since the logs tend to also be in UTC it makes for easier comparison.
Regardless, having the server in UTC vs you being in UTC+2 shouldn’t have any bearing on the MFA issue you were having. Since you mentioned it works for roughly a month after re-enabling it for a user it would seem like there is a very minuscule drift either on the clients generating the codes or the server itself.
How are your users generating the codes? Is everyone using whatever they want or do you have a centralized service for that?
Additionally could you post the output from timedatectl status on the server? That way maybe we can see if there is an offset or if it is running into issues keeping in sync
Everybody uses whatever they prefer, ms or google authenticators mainly.
timedatectl status:
Local time: Fri 2024-06-21 09:01:17 CEST
Universal time: Fri 2024-06-21 07:01:17 UTC
RTC time: Fri 2024-06-21 07:01:09
Time zone: Europe/Budapest (CEST, +0200)
System clock synchronized: yes
NTP service: active
RTC in local TZ: no
It looks like you’ve got an 8 second difference there
I corrected the 8 seconds now. It seems to be working but i need to test it in the long run, also 8 seconds diff shouldn’t cause the entire mfa to fail, should it?
8 seconds could be enough to throw off MFA for users. Might be worth monitoring to see if the drift comes back or not and compare that to the MFA failures if they happen again.
