Good afternoon, thanks for the reply,
Yes the emails are different D: , I’ll wait for that fix if it’s already coming.
Regarding SSL, yes it is enabled.
Passbolt API Status
PHP version 8.1.2-1ubuntu2.11.
PCRE compiled with unicode support.
The temporary directory and its content are writable and not executable.
The logs directory and its content are writable.
GD or Imagick extension is installed.
Intl extension is installed.
Mbstring extension is installed.
SSL access is enabled.
The application config file is present
The passbolt config file is present
Debug mode is off.
Cache is working.
Unique value set for security.salt
Full base url is set to https://192.168.69.21
App.fullBaseUrl validation OK.
/healthcheck/status is reachable.
The application is able to connect to the database
26 tables found
Some default content is present
The database schema up to date.
PHP GPG Module is installed and loaded.
The environment variable GNUPGHOME is set to /var/lib/passbolt/.gnupg.
The directory /var/lib/passbolt/.gnupg containing the keyring is writable by the webserver user.
The server OpenPGP key is not the default one
The public key file is defined in /etc/passbolt/passbolt.php and readable.
The private key file is defined in /etc/passbolt/passbolt.php and readable.
The server key fingerprint matches the one defined in /etc/passbolt/passbolt.php.
The server public key defined in the /etc/passbolt/passbolt.php (or environment variables) is in the keyring.
There is a valid email id defined for the server key.
The public key can be used to encrypt a message.
The private key can be used to sign a message.
The public and private keys can be used to encrypt and sign a message.
The private key can be used to decrypt a message.
The private key can be used to decrypt and verify a message.
The public key can be used to verify a signature.
The server public key format is Gopengpg compatible.
The server private key format is Gopengpg compatible.
Using latest passbolt version (3.11.0).
Passbolt is configured to force SSL use.
App.fullBaseUrl is set to HTTPS.
Selenium API endpoints are disabled.
Search engine robots are told not to index content.
The Self Registration plugin is enabled.
Registration is closed, only administrators can add users.
The deprecated self registration public setting was not found in /etc/passbolt/passbolt.php.
Host availability checking is disabled.
Serving the compiled version of the javascript app.
Some email notifications are disabled by the administrator.
