"NetworkError when attempting to fetch resource." when trying to add users to any group
(not an installation issue, this setup has been running for over 2 years - but as there is no category for general problem reports I posted in “installation issues”)
We can no longer add some users to any groups on our passbolt pro installation. The process always fails with “NetworkError when attempting to fetch resource.”
I haven’t found any similarities between the users that won’t work, i.e. I found 2 (out of 28) users by now that always fail for any group - one of them was created a few days ago, the other in November 2022.
passbolt 4.1.3
php 8.2.7 (also tried downgrading to version 8.1.20)
nginx 1.24.0 (on host and reverse proxy)
OS: FreeBSD 13.2-RELEASE-p1
openssl v1.1.1v
Healthcheck shows all “PASS”; except the always broken “…config/jwt directory should not be writeable” (which it is not) and 2 warnings about email notifications and smtp plugin endpoints being disabled.
As there are absolutely zero log-entries by passbolt about the event, I haven’t been abley to diagnose this properly.
Nginx (on host & reverse proxy), php-fpm and mysql logs are also clean.
  • add an existing user to an existing group and hit ‘save’
  • the progress bar reaches 96%, then it stalls
  • after several seconds (timeout) “NetworkError when attempting to fetch resource.” is displayed
I recently updated from 4.1.0 to 4.1.3, which went flawless without any errors 'as usual’™
Reverting the latest pkg upgrades also didn’t help as well as switching back from php8.2 to php8.1
Hello @sko ,
Since it looks like the issues is related to two users, does this is issues is also happening for new users or only those two?
Could you share the entire output of the status-report?
sudo su -s /bin/bash -c "/usr/share/php/passbolt/bin/status-report" www-data
Thanks for your Reply @antony
One of the users I can’t add to any group was created 6 days ago (but still on version 4.1.0) and just activated his account yesterday.
I first thought it might be the ‘ß’ in the username, but changing that to ‘ss’ didn’t solve the problem and we have users with umlauts that also don’t show any error. The second user I found also doesn’t have any special characters in its name; so that theory was quickly discarded.
I just tred to create a new test-user but that also fails with “NetworkError when attempting to fetch resource.”, so this seems to be a regression somewhere between 4.1.0 and 4.1.6?
Due to a wrong hard-coded path in utils.sh (‘/bin/bash’ - bash is never available in the base system on any BSD (or other unix like solaris/illumos for that matter)) - the “status-report” script doesn’t work under FreeBSD:
# bin/status-report www
su: unknown login: /bin/bash
So here’s the output of the 3 commands that this script tries to run:
root@passbolt:/usr/local/www/passbolt # su www -c 'bin/cake passbolt healthcheck'
The command should be executed with the same user as your web server. By instance:
su -s /bin/bash -c "/usr/local/www/passbolt/bin/cake COMMAND" HTTP_USER
where HTTP_USER match your web server user: www-data, nginx, apache, http
 [PASS] PHP version 8.2.7.
 [PASS] Full base url is set to https://passbolt.autogassner.de
 [PASS] 49 tables found
 [PASS] The environment variable GNUPGHOME is set to /usr/local/www/.gnupg.
 [PASS] The directory /usr/local/www/.gnupg containing the keyring is writable by the webserver user.
 [PASS] The public key file is defined in /usr/local/www/passbolt/config/passbolt.php and readable.
 [PASS] The private key file is defined in /usr/local/www/passbolt/config/passbolt.php and readable.
 [PASS] The server key fingerprint matches the one defined in /usr/local/www/passbolt/config/passbolt.php.
 [PASS] The server public key defined in the /usr/local/www/passbolt/config/passbolt.php (or environment variables) is in the keyring.
 [PASS] Using latest passbolt version (4.1.3).
 [PASS] The deprecated self registration public setting was not found in /usr/local/www/passbolt/config/passbolt.php.
 [HELP] Or set passbolt.email.validate.mx to true in /usr/local/www/passbolt/config/passbolt.php.
 [WARN] The JWT Authentication plugin is disabled
 [HELP] Set the environment variable PASSBOLT_PLUGINS_JWT_AUTHENTICATION_ENABLED to true
 SMTP Settings
 [HELP] Or set passbolt.security.smtpSettings.endpointsDisabled to true in /usr/local/www/passbolt/config/passbolt.php.
root@passbolt:/usr/local/www/passbolt # su www -c 'bin/cake passbolt cleanup --dry-run'
 Cleanup shell (dry-run)
11 issues found in table Passbolt/Folders.FoldersRelations (duplicated folders relations)
11 issues detected, please re-run without --dry-run to fix.
root@passbolt:/usr/local/www/passbolt # su www -c 'bin/cake passbolt datacheck --hide-success-details'
Data check shell
  [PASS] Can validate: 6548/6548
  [PASS] Can validate: 6/6
  [PASS] Can validate: 0/0
  [PASS] Can encrypt: 28/28
  [PASS] Pass validation service checks: 28/28
  [PASS] Entity data and armored key data matches: 28/28
  [PASS] Is not expired: 28/28
  [PASS] Is armored key format valid: 28/28
  [PASS] Can validate: 15/15
  [PASS] Can validate: 38/38
  [PASS] Can validate: 644/644
  [PASS] Can validate: 2745/2745
I let the ‘cleanup’ script fix the issues with the Passbolt/FoldersRelations, but this didn’t fix our problem:
I have created an internal ticket for this issues (PB-25799), since you are using Passbolt PRO could you contact us at support@passbolt.com linking this post? It will be easier for the follow-ups.
Thank you. I’m currently digging a bit deeper by incrementally restoring/rolling back the passbolt installation and/or packages and/or the whole jail from snapshots (while keeping the current database), so I might be able to find the last working state.
I’ll collect some more data from those attempts and will contact you via mail.
Do you have first the updating box working a bit and the unexpected error box appears after ~30 seconds ?
If yes, it is maybe a nginx timeout, and you may finds error message in nginx logs.
It is just a guess :slightly_smiling_face:
The progress bar reaches 96% at a reasonable time, then stalls for ~30 seconds until the “unexpected error” message is shown.
I don’t have any errors logged at the local or reverse proxy nginx - both ‘access.log’ show successful delivery of the ‘app/groups’ or ‘app/users’ page, the error.log remains silent during the whole process.
Also, that whole setup (including the reverse proxy) was running for >2 years now, the whole nginx config hasn’t been touched for months and the ‘server’ block for passbolt very likely since it has been set up…
Could you share the passbolt logs? Usually they are located in /var/log/passbolt/error.log but I can’t tell on FreeBSD since we are not officially supporting it.
Also, the payload from the API requests could give more details here, depending from your browser you could:
  1. Go to Developer Tools < Network
  2. Reproduce the behaviour
  3. Find the request sent to the Passbolt API
  4. Share the output
Thanks :slightly_smiling_face:
Sorry for the long silence.
The problem seems related to our reverse proxy setup. The proxy jail was migrated to another host (i.e. moving the config to a newly set up jail) and it somehow triggers this error with Passbolt.
Using the old jail (even on the same host) solves the problem immediately.
Both jails are configured identical (network interfaces/IPs) and use the same nginx version and config. I haven’t found the time yet to further troubleshoot this, so I’m just using the ‘old’ jail in the meantime…
So in essence, I’m not so sure any more if this really is a problem with Passbolt, although anything else behind the reverse proxy works just fine as is to be expected if using the same OS and package versions and config…
