Do you know of any way to move forward?
We can try to help you by having a look. You can run the following SQL query and past the output here. Or DM me if you’re not comfortable sharing this info publicly.
select * from gpgkeys where user_id = (select id from users where username = 'ada@passbolt.com');
Replace ada with the email of one user that cannot login.
I sent you a private message
i have the same problem with the update… could you fix??
I have to restart the server to be able to log in again.
When I log out and want to start again, it says authentication failed
2023-07-03 15:34:45 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentica tion/src/Controller/Component/AuthenticationComponent.php on line 177
Client IP: 192.168.0.105
2023-07-03 15:34:52 error: [Cake\Http\Exception\InternalErrorException] The authentication failed. in /usr/share/php/passbolt/src/Controller/Auth/AuthLoginController.php on l ine 93
Request URL: /auth/login.json?api-version=v2
2023-07-03 15:34:52 error: The authentication failed.
2023-07-03 15:34:52 error: #0 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Controller/Controller.php(547): App\Controller\Auth\AuthLoginController->loginPost()
#1 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Controller/ControllerFactory.php(139): Cake\Controller\Controller->invokeAction()
#2 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Controller/ControllerFactory.php(114): Cake\Controller\ControllerFactory->handle()
#3 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/BaseApplication.php(320): Cake\Controller\ControllerFactory->invoke()
#4 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(86): Cake\Http\BaseApplication->handle()
#5 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Middleware/SecurityHeadersMiddleware.php(255): Cake\Http\Runner->handle()
#6 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(82): Cake\Http\Middleware\SecurityHeadersMiddleware->process()
#7 /usr/share/php/passbolt/src/Middleware/HttpProxyMiddleware.php(50): Cake\Http\Runner->handle()
#8 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(82): App\Middleware\HttpProxyMiddleware->process()
#9 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Middleware/CsrfProtectionMiddleware.php(138): Cake\Http\Runner->handle()
#10 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(82): Cake\Http\Middleware\CsrfProtectionMiddleware->process()
#11 /usr/share/php/passbolt/plugins/PassboltCe/JwtAuthentication/src/Middleware/JwtCsrfDetectionMiddleware.php(55): Cake\Http\Runner->handle()
#12 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(82): Passbolt\JwtAuthentication\Middleware\JwtCsrfDetectionMiddleware->process()
#13 /usr/share/php/passbolt/src/Middleware/GpgAuthHeadersMiddleware.php(40): Cake\Http\Runner->handle()
#14 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(82): App\Middleware\GpgAuthHeadersMiddleware->process()
#15 /usr/share/php/passbolt/plugins/PassboltCe/Locale/src/Middleware/LocaleMiddleware.php(47): Cake\Http\Runner->handle()
#16 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(82): Passbolt\Locale\Middleware\LocaleMiddleware->process()
#17 /usr/share/php/passbolt/plugins/PassboltCe/MultiFactorAuthentication/src/Middleware/InjectMfaFormMiddleware.php(67): Cake\Http\Runner->handle()
#18 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(82): Passbolt\MultiFactorAuthentication\Middleware\InjectMfaFormMiddleware->process()
#19 /usr/share/php/passbolt/plugins/PassboltCe/MultiFactorAuthentication/src/Middleware/MfaRequiredCheckMiddleware.php(82): Cake\Http\Runner->handle()
#20 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(82): Passbolt\MultiFactorAuthentication\Middleware\MfaRequiredCheckMiddleware->process()
#21 /usr/share/php/passbolt/vendor/cakephp/authentication/src/Middleware/AuthenticationMiddleware.php(124): Cake\Http\Runner->handle()
#22 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(82): Authentication\Middleware\AuthenticationMiddleware->process()
#23 /usr/share/php/passbolt/plugins/PassboltCe/JwtAuthentication/src/Middleware/JwtDestroySessionMiddleware.php(43): Cake\Http\Runner->handle()
#24 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(82): Passbolt\JwtAuthentication\Middleware\JwtDestroySessionMiddleware->process()
#25 /usr/share/php/passbolt/src/Middleware/SessionAuthPreventDeletedUsersMiddleware.php(46): Cake\Http\Runner->handle()
#26 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(82): App\Middleware\SessionAuthPreventDeletedUsersMiddleware->process()
#27 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Middleware/BodyParserMiddleware.php(162): Cake\Http\Runner->handle()
#28 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(82): Cake\Http\Middleware\BodyParserMiddleware->process()
#29 /usr/share/php/passbolt/src/Middleware/SessionPreventExtensionMiddleware.php(66): Cake\Http\Runner->handle()
#30 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(82): App\Middleware\SessionPreventExtensionMiddleware->process()
#31 /usr/share/php/passbolt/src/Middleware/ApiVersionMiddleware.php(46): Cake\Http\Runner->handle()
#32 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(82): App\Middleware\ApiVersionMiddleware->process()
#33 /usr/share/php/passbolt/plugins/PassboltCe/JwtAuthentication/src/Middleware/JwtRouteFilterMiddleware.php(47): Cake\Http\Runner->handle()
#34 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(82): Passbolt\JwtAuthentication\Middleware\JwtRouteFilterMiddleware->process()
#35 /usr/share/php/passbolt/plugins/PassboltCe/JwtAuthentication/src/Middleware/JwtAuthDetectionMiddleware.php(58): Cake\Http\Runner->handle()
#36 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(82): Passbolt\JwtAuthentication\Middleware\JwtAuthDetectionMiddleware->process()
#37 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/Middleware/RoutingMiddleware.php(186): Cake\Http\Runner->handle()
#38 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(82): Cake\Routing\Middleware\RoutingMiddleware->process()
#39 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/Middleware/AssetMiddleware.php(77): Cake\Http\Runner->handle()
#40 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(82): Cake\Routing\Middleware\AssetMiddleware->process()
#41 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Error/Middleware/ErrorHandlerMiddleware.php(131): Cake\Http\Runner->handle()
#42 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(82): Cake\Error\Middleware\ErrorHandlerMiddleware->process()
#43 /usr/share/php/passbolt/src/Middleware/ContentSecurityPolicyMiddleware.php(39): Cake\Http\Runner->handle()
#44 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(82): App\Middleware\ContentSecurityPolicyMiddleware->process()
#45 /usr/share/php/passbolt/src/Middleware/ContainerInjectorMiddleware.php(54): Cake\Http\Runner->handle()
#46 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(82): App\Middleware\ContainerInjectorMiddleware->process()
#47 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Runner.php(67): Cake\Http\Runner->handle()
#48 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Http/Server.php(90): Cake\Http\Runner->run()
#49 /usr/share/php/passbolt/webroot/index.php(40): Cake\Http\Server->run()
#50 {main}
We have not been able to fix the issue yet
waiting on @remy for any resolution
@shkarface I checked the key and it is fine. I’m not sure sure why however the fingerprint is ending with a Q in the database. This is not a correct fingerprint. You can try to rename the fingerprint in the database to remove the trailing Q.
update gpgkeys set fingerprint='7BA18F137CAF2AD47602F5D70D1465FF8E54F8C4' where fingerprint='7BA18F137CAF2AD47602F5D70D1465FF8E54F8C4Q';
update gpgkeys set fingerprint='E58599258FC30BD443918E7A75272900CA7E0DE3' where fingerprint='E58599258FC30BD443918E7A75272900CA7E0DE3Q';
update gpgkeys set fingerprint='9ED4182C336A03DCBB3928C1F4A098D575F13C2C' where fingerprint='9ED4182C336A03DCBB3928C1F4A098D575F13C2CQ';
update gpgkeys set fingerprint='1EB47508C31498F0B580438D671BF639FFEA1821' where fingerprint='1EB47508C31498F0B580438D671BF639FFEA1821Q';
update gpgkeys set fingerprint='4B9ADB17A61B5824CB03E69233C654DE7BEF8349' where fingerprint='4B9ADB17A61B5824CB03E69233C654DE7BEF8349Q';
Then rerun the data check and try to see if the issue is fixed.
@Jose please start a new thread, while the symptoms may be the same, this may not be the same error. We also need your data to evaluate (status-report with healthcheck, data-check, cleanup results etc.)
Hello @remy, thank you very much for the solution, this worked like a charm.
It’s very weird that this issue has happened during the upgrade, are there any internal bugs related to this?
I gave a look at the code we have to see if there was a bug in our process. I couldn’t find anything yet on my side, it could be the browser extension, the API, some API internal process. I have no clue to be honest.
So, I was wondering, if you still have the SQL export you did before converting, could you check if the backup files contains the Q in the fingerprint please (I’m trying to narrow down the potential source of the problem)?
Hello Steph,
Yes the Q is in the previous database as well, this is where the initial issue happened.
That’s why we converted from a docker installation to an ubuntu installation so we can easier troubleshoot it.
EDIT: and this happened after upgrading passbolt to v4
This is very strange since there is no migration on fingerprint field as part of v4 (and the last one touching that field is v2.0.2 which is from 2018, before the keys were created). What was your upgrade procedure, how did you migrate to a new server and/or export / import data using SQL? Maybe there was an initial charset misconfiguration?
We just exported from the docker and imported in the VM.
keep in mind that the issue happened before moving from docker to VM.
Also, it has stopped working again
It stops again?! With the same issue (having a Q at the end of some fingerprints in the database)?
Yes, it seems that was the case, some of the fingerprints had the letter Q appended to their end.
(Not all of them though)
I can confirm that this is the case, the fingerprints get a ‘Q’ appended to the after some time, I don’t know exactly is the issue
The fingerprints that get changed are random I think?
I’ve had to run multiple commands like these in the past hour:
mysql> UPDATE gpgkeys SET fingerprint = "" WHERE fingerprint = "";
Query OK, 0 rows affected (0.00 sec)
Rows matched: 0 Changed: 0 Warnings: 0
mysql> UPDATE gpgkeys SET fingerprint = "7BA18F137CAF2AD47602F5D70D1465FF8E54F8C4" WHERE fingerprint = "7BA18F137CAF2AD47602F5D70D1465FF8E54F8C4Q";
Query OK, 1 row affected (0.00 sec)
Rows matched: 1 Changed: 1 Warnings: 0
mysql> UPDATE gpgkeys SET fingerprint = "E58599258FC30BD443918E7A75272900CA7E0DE3" WHERE fingerprint = "E58599258FC30BD443918E7A75272900CA7E0DE3Q";
mysql> UPDATE gpgkeys SET fingerprint = "5DE165BF83F4516012B7B38A3B5F2393CD881968" WHERE fingerprint = "5DE165BF83F4516012B7B38A3B5F2393CD881968Q";
Query OK, 1 row affected (0.01 sec)
mysql> UPDATE gpgkeys SET fingerprint = "A0ACFF99A2CFE22262C8EE1BEC99C30D202D8DA2" WHERE fingerprint = "A0ACFF99A2CFE22262C8EE1BEC99C30D202D8DA2Q";
mysql> UPDATE gpgkeys SET fingerprint = "BDF361329C1F591B4FFCCD9A83FB475685D243AC" WHERE fingerprint = "BDF361329C1F591B4FFCCD9A83FB475685D243ACQ";
That’s a very weird one
Do you know:
- if it happens for the same users as before, or if it’s for random users, or new users?
- which browser are they using?
By the way, we looked at what are tested automatically, we don’t go (yet) over mariadb 10.6.
I’m will to a test with the 10.11.
It usually happens to the same set of users…
This is breaking the system entirely, we can jump on a call to see if we can find the issue
