Hello all,
During the passbolt installation I skipped smtp server configuration,after installation I edit config ‘EmailTransport" in config/passbolt.php and now I can’t open passbolt from web console
Hi @sansandrika passbolt_api/passbolt.default.php at master · passbolt/passbolt_api · GitHub Has the default content if you are looking to replace/paste the section back in. That file should also be on your server, but just in case it isn’t I thought I would provide the source for you.
Thank you I already fixed it
