I mistyped the SMTP settings during configuration wizard.
Anybody know the complete path to change the SMTP settings on a debian installation?
Cant find it.
Hi @oformoso,
You will want to make the needed changes in the passbolt.php
config file which is located in the/etc/passbolt
folder.
The passbolt.default.php
file in the same folder shows the template in original form, which you can use for reference if needed. Specifically, you’ll be looking for the EmailTransport
block:
// Email configuration.
'EmailTransport' => [
'default' => [
'host' => 'localhost',
'port' => 25,
'username' => 'user',
'password' => 'secret',
'tls' => null,
//'timeout' => 30,
//'client' => null,
//'url' => null,
