Hi!
I installed passbolt on an Ubuntu Server with nginx The APP BASE URL for me is IP/passbolt
For me the installation didn’t return a successful message, it redirected me to an URL: with /setup/install, which is just a white blank page.
When I navigate to the base URL, the page title is “Passbolt | Not Found” with page contents:
Not Found
The requested address was not found on this server. Please double check the url. Maybe the page was deleted or moved.
- [Terms]
- [Credits]
- [Versions]
Am I missing something here?
Thanks in advance !!
Hey @dghimire welcome to the forum!
How are you installing this? Via docker/helm or one of the packages for like debian or rocky?
Since you are trying to install as IP/passbolt you’ll need to use a couple non-standard options
Hi there,
I installed it into a Ubuntu system with nginx.
Alright, did you set this up with SSL/TLS or did you select none?
Typically with a white screen at this stage there is a mismatch with the URL you have in the browser and what you have entered in the passbolt installation options.
Hi there,
I did a setup on a Virtual server without SSL and one on a live server with SSL (nginx in both cases). After installation I am at this screen (see screenshot) in both cases.
When I type in the IP that is the same one I used during installation, I am redirected to http://192.168.64.10/auth/login?redirect=%2F without any content.
Going to http://192.168.64.10/passbolt (URL for installation() gets me to anothe blnk page:
