Hi!
I am newbie using passbolt. I installed passbolt to Debian 10 using the script from the site. I change or tried to change the point to access a passbolt, https://server.com/pass, but now I cant access the passbolt server page, the installation was sucessful because I did everything fine, at last that told me the wizard.
When I point to my server, https://myserver/pass, I get this ::
[PASS] PHP version 7.3.11-1~deb10u1.
[PASS] Full base url is set to https://myserver.com/pass
[PASS] 23 tables found
[PASS] The environment variable GNUPGHOME is set to /yuca/www-data/.gnupg.
[PASS] The directory /yuca/www-data/.gnupg containing the keyring is writable by the webserver user.
[PASS] Using latest passbolt version (2.12.0).
Thank you for providing the logs. You asked about the Nginx config file from the passbolt installation. It is found in /etc/nginx/conf.d folder.
You could verify what is showing next to the “server_name” parameter. Should be your domain. If you can also check logs in /var/log/nginx and see if there are errors there as well to report.
