[x] I have read intro post: ****
Latest version of Passbolt community edition on CentOS 7.
passbolt.php email settings:
// Email configuration.
‘EmailTransport’ => [
‘default’ => [
‘host’ => ‘smtp.mysmtp.net’,
‘port’ => 587,
‘username’ => ‘’,
‘password’ => '’,
‘tls’ => true,
//‘timeout’ => 30,
//‘client’ => null,
//‘url’ => null,
I can view the mail queue with cake preview. But cake sender --verbose has absolutely no output. The test email does send fine. I have sent it multiple times. The cron job is setup with the nginx user. I see no errors in there and just the EmailQueue.sender command being run.
I have verified all notification emails are configured to be sent out.
[root@passbolt bin]# sudo su -s /bin/bash -c “/var/www/passbolt/bin/cake passbolt healthcheck” nginx
// _,///./_//__/
[PASS] PHP version 7.3.14.
[PASS] Full base url is set to *****
[HELP] cURL Error (60) Peer’s Certificate issuer is not recognized.
[PASS] 23 tables found
[PASS] Using latest passbolt version (2.12.0).
[WARN] Registration is open to everyone.
[HELP] Or set passbolt.registration.public to false in config/passbolt.php.
I have looked in every log file I could find and see absolutely no errors related to failed emails.
