Restoring/ Updating from 2.5.0 to 3.2.1
I am currently trying to restore my passbolt instance from an old installation (version 2.5.0) and I am hitting a wall with the below database schema error with the configuration gui.
I am moving from an old server to a new machine with a fresh install of ubuntu server 21.04 and have followed the instructions for the installation of passbolt-ce (installed via apt-get version 3.2.1-3)
I then restored the database and copied the gpg folder over to /etc/passbolt
I don’t get any issues with the system check and I don’t have any logs in /var/log/passbolt
please advise
Hi @rockshiba Passbolt Help | Migrate passbolt CE from install scripts to Ubuntu package
This is the official upgrade guide. Sounds like you are at step 8. Will this work for you?
That seemed to have worked, thank you! :slight_smile:
