We have upgrade our 1.6.9 (initial installation) to 1.6.10 and then upgrade centos from 7.4 to 7.5 and passbolt from 1.6.0 to 2.0.7.
All looks good but after the upgrade there are two problems:
- Not all items from a group are shown as used the ‘filter by groups’ option
- all inputs in the search field would select all items ~ there is no filtering
I see in my health check that we have 19 tables in database but normally the posts are show 23 db tables.
Here my db table list:
| Tables_in_passbolt |
| authentication_tokens |
| burzum_file_storage_phinxlog |
| comments |
| email_queue |
| email_queue_phinxlog |
| favorites |
| file_storage |
| gpgkeys |
| groups |
| groups_users |
| permissions |
| phinxlog |
| profiles |
| resources |
| roles |
| secrets |
| user_agents |
| users |
| users_resources_permissions |
Any idea how to solve it? Thank You
Installation:
- centos 7.4 -> centos 7.5
- mariadb-server-5.5.56-2.el7.x86_64
- nginx-1.13.12-1.el7_4.ngx.x86_64
- php70w-fpm-7.0.29-1.w7.x86_64
- passbolt 1.6.9 -> 1.6.10 -> 2.0.7
bash-4.2$ bin/cake passbolt healthcheck
// _,///.__/__//_/
[PASS] PHP version 7.0.29.
[PASS] Full base url is set to http://passbolt1.lnwsoft.corp
[PASS] 19 tables found
[PASS] The environment variable GNUPGHOME is set to /var/cache/nginx/.gnupg.
[PASS] The directory /var/cache/nginx/.gnupg containing the keyring is writable by the webserver user.
[PASS] Using latest passbolt version (2.0.7).
