Update Issues from V2.5.0
Hi Everyone,
I am seeking some help, I have the CE Version of Passbolt on CentOS 7 ( Passbolt Version 2.5.0) and I have been trying to update to the latest version with no luck.
Each time I try and update by following the guide https://help.passbolt.com/hosting/update (running as the nginx user) things seem to go fine… but when I go to the login page and enter my login details I get the following error “There was a server error. No additional information provided(502)” and can not login.
I have tried updating both via one version at a time and by just updating to the current release but I get the same error.
Any one have any ideas, Or should I do a fresh install and restore the DB to it… ? Is that even possible ? What would be the best course of action to get this resolved.
Hello @exilewolf,
What is the output of the health check command su -s /bin/bash -c "./bin/cake passbolt healthcheck" www-data ?
Is there anything that could help us to understand the issue in the passbolt logs (/var/www/passbolt/logs/error.log) and in the webserver logs (/var/log/nginx/error.log) ?
Hey @cedric
I will need to try the upgrade again to get that information for you as I had to roll back the change so the system could be usable again. I will not be able to preform this until next week. As soon as I do I will update here with what I have found.
Looks like my Passbolt is really screwed up :frowning: this is what I pulled from the health check and the nginx log.
/ _
//./_//__/
[PASS] PHP version 7.2.10.
[PASS] Full base url is set to https://xxx
[HELP] cURL Error (60) Peer’s Certificate issuer is not recognized.
[PASS] 23 tables found
[PASS] Using latest passbolt version (2.11.0).
PHP message: PHP Warning: file_put_contents(/var/www/passbolt/logs/error.log): failed to open stream: Permission denied in /var/www/passbolt/vendor/cakephp/cakephp/src/Log/Engine/FileLog.php on line 133
2019/10/15 21:50:44 [error] 2300#0: *9 upstream sent too big header while reading response header from upstream, client: xxx.xxx.xxx.xxx, server: , request: “POST /auth/login.json?api-version=v1 HTTP/1.1”, upstream: “fastcgi://127.0.0.1:9000”, host: “”
