This is an in place upgrade, following the instructions on the site. The old version did run, and was online. Post upgrade, the requeted URL’s are no longer found. The SSL Cert is working with Apache, you can see it on the 404 page that is loaded.
The site configuration in apache does have the DocumentRoot as /var/www/passbolt None of that changed from 1.6.10.
Any ideas?
[PASS] PHP version 7.0.30-1+ubuntu14.04.1+deb.sury.org+1.
[PASS] Full base url is set to https://************
[PASS] 19 tables found
[FAIL] This installation is not up to date. Currently using 2.0.5 and it should be v2.0.7.
