SMTP timeout or Yndex.ru and mail.ru
SMTP server is not working.
I read all the articles on the forum and checked absolutely everything.
I checked su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake passbolt healthcheck --application --configFiles --core --database --environment --ssl" www-data
I checked su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake passbolt healthcheck --gpg --smtpSettings" www-data
I tried adding 25, 465, 587 and disabling UFW and disable TLS.
My SMTP server has parameters:
the address of the mail server is smtp.yandex.ru ;
connection protection β€” SSL;
port β€” 465.
Hi @Radmil Thanks for the info, we will need just a bit more. What flavor OS and version method did you install?
For outgoing smtp from passbolt, the passbolt server firewall need not be changed as it is not receiving, only sending.
There is a command on the linked page above for testing outgoing mail. Can you post what error you are getting?
Passbolt CE 3.8.3
Cakephp 4.3.7
Linux Server2105010 5.15.0-56-generic #62-Ubuntu SMP Tue Nov 22 19:54:14 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
PHP 8.1.2-1ubuntu2.9 (cli) (built: Oct 19 2022 14:58:09) (NTS)
mysql Ver 8.0.31-0ubuntu0.22.04.1 for Linux on x86_64 ((Ubuntu))
gpg (GnuPG) 2.2.27
libgcrypt 1.9.4
Solved the problem like this
