This is in Java. The fingerprint is absolutely the same one as on my user page. This one is just an example. Is it the fingerprint format? The message format? The server lets me go a little further and then I get a 401 on /users/me.json.
post content: {“data”:{“gpg_auth”:{“keyid”:“ABBAABBAABBAABBAABBAABBAABBAABBAABBAABBA”,“server_verify_token”:null,“user_token_result”:null}}}
response code 200 body {“header”:{“id”:“b0d7beb3-a5a5-41ba-be0f-f4aaabf1f011”,“status”:“error”,“servertime”:1699501407,“action”:“a3c19ad2-8920-5395-86d0-8567cb34f382”,“message”:“The authentication failed.”,“url”:“/auth/login.json”,“code”:200},“body”:null}
We really need some context here in order to understand what is clearly happening there, which steps have been taken to be there, how could we reproduce etc…
Also, if you are trying to use the API with Java and you’re experiencing some issues with the authentication, just in case you could take a look at how it’s done for our mobile application that uses Kotlin
