I have an issue enabling MFA at my installation
In user profile I enable MFA, scan the code with TOTP software, enter confirmation code - Passbolt accepts it
then it asks to enter TOTP - and here’s the issue - after entering the code I asked to enter code again and again. There’s no message that code is incorrect.
If I enter expired or wrong code - I get error, but if I enter correct TOTP - just asks again
Hi @xaaru
For your information, if you are using passbolt PRO, you can request pro support on support@passbolt.com.
On the other hand, did you configured HTTPS on your passbolt instance ? MFA won’t work without SSL enabled.
Trial PRO, in test environment
thanks, that’s the key, haven’t seen that requirement. didn’t push SSL on demo. will try, thank you
