Using the New V3.0.5 Extension with a V2 PRO Server Exporting Breaks with the error “Could not validate entity ExternalFolder.” if there are special characters like a slash (/) in a Folders name that is going to be exported. Apparently the Folder Name / Rename Validation checks differently that the Extension Validates the Folder Names.
Hi @Speatzle Can you please send the example details to support@passbolt.com since you are using the PRO version? Thanks.
