Using Passbolt in different Browser at the same time
Is it possible to use Passbolt with different browsers at the same time? Is this problem solved with the Desktop app? Or will this problem be solved any time?
Hello @MauriceGutmann and welcome to the forum.
Yes, it is possible to use Passbolt on different browsers or devices at the same time.
But, just to know more about your use case, why do you need to use it in more than one browser at the same time if you can only use one browser at a time?
Hello @Termindiego25, its to test an application in different Browsers, with different accounts. But my problem is solved already.
