So i was just wondering… I’m hosting a bunch of 3CX PBX’s which have (for about 80%) the same url.
Is there a way to use something like a wildcard.
All our customers do have a URL like: https://wildcard.fluxcloud.eu were the part “wildcard” is different per customer.
Now i have to create an entry per customer which give’s me about 120 of them
@MDLefevere Just to confirm, you’re asking if the URL field of the shared password with a customer can have a wildcard so their navigation to their own subdomain for your service would recognize they are on that wildcarded URL?
But… all of your customers have the same password to each of their separate domains?
Yes. It’s an endportal which i use to control it. It is not customer allowed.
The password is one of the most terrible i’ve even seen, so yes, they have the samen password. I quess it’s about 35 chars long
@MDLefevere Ah, gotcha. Well, you’re in luck because the URL is not a blocking feature. If you name the password something like PORTAL in the name field, you can easily search it in the extension and use the credentials to whatever site you are currently on. Even if the URLs don’t match.
@remy My understanding is that protocol and port are both hard settings. For example, https://something.fluxcloud.eu would not get picked up with http://fluxcloud.eu. Is that correct?
