Hello all,
I have recently discovered this service but it isn’t available for my phone.
Even if I search it from web’s Play Store, it reports that the app isn’t available for this phone model
Here some additional phone details:
Model: Redmi Note 8 Pro
MIUI: Global 11.0.3
Android Version: 9PPR1
Any suggestion?
Just now I have read that Android 10 is the minimal version required.
Actually there is an update for my phone to Android 10 but I cannot get it installed via OTA.
So I need to follow a more invasive procedure to upgrade that I cannot perform now 'cause I need the phone for work.
No way to have the client app available for Andoird 9?
Thanks
It’s hard to make 9 greater than or equal to 10.
Not to mention running Android API 29 on version 9. But, if you can get API 29 running, that’s what you really need.
And welcome to the forum!
