I have used the AWS Passbolt AMI Community to install passbolt in EC2.
Followed the instructions here: Passbolt Help | Using Passbolt CE AWS AMI
Key Pair Created correctly and instance spun up ok
I am however unable to connect to configure HTTPS using:
EC2 Instance Connect or using an SSH Client
I get an
" * Failed to connect to your instance
Error establishing SSH connection to your instance. Try again later."
I tried with root, admin, ec2-user
Any thoughts on getting me past the first hurdle?
Many thanks.
