Can't access web interface
I am using passbolt for the first time, the docker-compose version on Linux 20.04. In my command line everything seems to be running, but I can’t open the web interface. I have passbolt plugin installed, but that just tells me, that it requires the server to work. I’m not quite sure if I was supposed to do something else before running the docker-compose up.
I have also changed passbolt ports in docker-compose.yml to:
- 8880:80
- 8443:443
but after trying localhost:8880 I get relocated to https:// passbolt.local/auth/login and Server Not Found error.
healthcheck:
/ / __ `/ / / __ / __ / / _/
/ _
//./_//__/
[PASS] PHP version 7.3.21.
[PASS] Full base url is set to https://passbolt.local
[HELP] cURL Error (6) Could not resolve host: passbolt.local
[PASS] 23 tables found
[PASS] Using latest passbolt version (2.13.5).
[WARN] Registration is open to everyone.
[HELP] Or set passbolt.registration.public to false in config/passbolt.php.
By default passbolt will try to enforce https. You should be able to access passbolt at https://localhost:8443. If you want to access it with http (which is a bad idea in production, but for testing it’s ok), you will need to set the environment variable to PASSBOLT_SSL_FORCE to false.
Also it seems the URL is set to https://passbolt.local and you want it to be localhost.
You can redefine the host using the APP_FULL_BASE_URL environment variable to localhost. Alternatively you can map passbolt.local in your /etc/host file on your local machine.
127.0.0.1       passbolt.local
The problem is that whatever I do I get “We can’t connect to the server at www.passbolt.local.” or something along these lines, including https://localhost:8443. When I connect to said adresses, the log in command lines writes:
passbolt_1 | 127.0.0.1 - 18/Aug/2020:10:44:53 +0000 “GET /index.php” 302
passbolt_1 | 172.22.0.1 - - [18/Aug/2020:10:44:53 +0000] “GET / HTTP/1.1” 302 5 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0”
but in browser I get Server Not Found error
Got it,
it turned out that I just didn’t understand your answer. Changing PASSBOLT_SSL_FORCE to false and changing APP_FULL_BASE_URL to http://localhost:8880 did the trick.
Thank you very much for your help.
