Centos 8 Install script
I’ve fixed your centos 7 install script to work with centos 8.
Where would I be able to upload it?
Here is it’s temporary github location.
Thanks
PS, sorry if this is under the wrong category. Please move if required.
Thinking of adding “pinentry” to the packages list. incase user wants to create gpg key’s locally on the system.
Opinions?
Hi @TheDeadGuy !
Thanks for your contribution! It is aweseome!
It would be even better if you could take a look on how we organize the code in GitHub - passbolt/passbolt_install_scripts: Passbolt CE installation scripts so you can make a pull request with your changes on the specific files instead of in the final build script as it will be easier for us to review and accept your changes on the repo!
