please help with this error. Menu “Administration”
an error start on 2.11 version and now present on 2.12
Thanks
Hello @sergiys,
In order to help you, can you please copy/paste here:
1.
3.error log
2019-12-26 14:13:03 Error: [Cake\Routing\Exception\MissingControllerException] Controller class NotificationOrgSettingsGet could not be found.
Request URL: /settings/emails/notifications.json?api-version=v2
Referer URL: http://10.10.2.23/app/administration/email-notification
2019-12-26 14:13:04 Error: [Cake\Routing\Exception\MissingControllerException] Controller class NotificationOrgSettingsGet could not be found.
2019-12-26 14:13:05 Error: [Cake\Routing\Exception\MissingControllerException] Controller class NotificationOrgSettingsGet could not be found.
While following the update documentation, did you get an error with the steps 2 or 4 of the Minor update section?
Step2: Upgrade the project dependencies
composer install --no-dev
Step4: Clean cache
./bin/cake cache clear_all
Can you execute these commands again and copy/paste the result of them if any errors.
If the problem persists can you share with us:
su -s /bin/bash -c "/var/www/passbolt/bin/cake passbolt healthcheck --gpg" nginx
step 2. No. I am not using docker
step 4 Yes
This step is mandatory for non docker install.
Can you run it and let us know what is the output.
ok. I installed composer, run the command. Now it’s working. thanks!!!
Great, glad to read the problem is solved.
Have a great end of year.
Thanks! To you too!
by the way. Healthcheck inform me:
Is it critical? Could I solve this issue?
Regards.
It is not critical, but gpg is producing warning when a gpg key without valid email id is used to encrypt content.
Thanks a lot!
Regards!
