Hello I recently upgraded to 2.10.0 and I am running into an issue where I can’t add new users to a group that has 2000+ passwords. Before the upgrade this was not an issue. Load time of put request is 41 seconds therefore it is unlikely that it’s hitting a timeout
HTTP/1.1 400 Bad Request
Date: Thu, 13 Jun 2019 11:37:31 GMT
Server: Apache
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate
Pragma: no-cache
strict-transport-security: max-age=31536000; includeSubDomains
Content-Length: 297
Connection: close
Content-Type: application/json; charset=UTF-8
{"header":{"id":"f1ba2dXXXXXee1b2","status":"error","servertime":1560425895,"title":"app_groups_update_error","action":"3303ccc6XXXXXXXX756217d","message":"Not Found","url":"\/groups\/5aXXXX1aa.json?api-version=v1","code":400},"body":[]}
passbolt error log says:
2019-06-13 11:38:15 Error: [App\Error\Exception\ValidationException] Could not validate group data.
Request URL: /groups/5ab4eXXXX9c1aa.json?api-version=v1
I attempted to clean the database there where 7 records but it didn’t solve the issue.
Cleanup shell (delete mode)
[PASS] PHP version 7.
[PASS] Full base url is set to …
[PASS] 24 tables found
[PASS] Using latest passbolt version (2.10.0).
