This sends mails to an inexistent receiver address doesnotexist@passboltdummydomain.com
But where can I find this address and delete it? It is not in the database.
As long as I can not remove this, the crob job for emails is unusable, as it fills the queue of the receiving smtp service with unsuccessful (but processed) jobs …
hi @Thommie, as far as I know all the user emails are stored in the database. Are you sure you checked with in your database with: select * from users where username='doesnotexist@passboltdummydomain.com';
Do you have a sample message, e.g. what kind of emails is it trying to send?
I could not find this "doesnotexist@passboltdummydomain.com" in the database. Nevertheless I re-installed the database now, as it was nearly empty. Maybe the effect is gone now …
Even after a re-initialisation of passbolt and re-installation of the whole database ( sudo su -s /bin/bash -c „./bin/cake passbolt install“ www-data) I still see those “dummy mails”:
Mar 6 15:34:01 mail postfix/smtp[15206]: 3F4D219F93D: to=doesnotexist@passboltdummydomain.com, relay=outbound.mailhop.org[35.157.29.171]:2525, delay=27905, delays=27902/0.02/2.6/0.13, dsn=4.7.1, status=deferred (host outbound.mailhop.org[35.157.29.171] said: 450 4.7.1 Recipient address rejected: Recipient blocked: domain doesn’t exist (in reply to RCPT TO command))
I already did that test successfully, the mail setup is finished. But the dummy address is still in the mail queue and creates jobs on the receiving smtp providers queue. I see no way how to remove this dummy …
You can clear the email queue by deleting entries in the database table email_queue. delete from email_queue, but I’m not sure how this email ends up in the passbolt email queue (it shouldn’t). Could it be you need to clear the postfix queue instead?
