[FreeBSD 11.1] Block at final step
Hi everyone,
I follow this guide : https://help.passbolt.com/hosting/install/ce/from-source to install in iocage freebsd.
Apache 2.4 and php7.2 works perfectly : test phpinfo()
I got my SSL certs with let’s encrypt (with wildcard for subdomains like passbolt)
Here the result of ./bin/cake passbolt healthcheck
 [PASS] PHP version 7.2.10.
 [PASS] Full base url is set to https://passbolt.opti-it.fr
error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed
fopen(https://passbolt.opti-it.fr/healthcheck/status.json): failed to open stream: operation failed
 [PASS] 18 tables found
 [PASS] The environment variable GNUPGHOME is set to /home/passbolt/.gnupg.
 [PASS] The directory /home/passbolt/.gnupg containing the keyring is writable by the webserver user.
 [PASS] Using latest passbolt version (2.4.0).
And here the log of httpd-error.log when I try to attempt the web site
[Wed Nov 07 13:06:14.841531 2018] [php7:error] [pid 78085] [client 192.168.144.6:51194] PHP Fatal error:  [Error] Call to undefined function Cake\\Network\\session_status()\n#0
/usr/local/www/apache24/data/passbolt/vendor/cakephp/cakephp/src/Network/Session.php(218): Cake\\Network\\Session->options(Array)\n#1 /usr/local/www/apache24/data/passbolt/vendor/cakephp/cakephp/src/Network/Session.php(125): Cake\\Network\\Session->__construct(Array)\n#2 /usr/local/www/apache24/data/passbolt/vendor/cakephp/cakephp/src/Http/ServerRequestFactory.php(47): Cake\\Network\\Session::create(Array)\n#3 /usr/local/www/apache24/data/passbolt/vendor/cakephp/cakephp/src/Http/ServerRequest.php(232): Cake\\Http\\ServerRequestFactory::fromGlobals()\n#4 /usr/local/www/apache24/data/passbolt/vendor/cakephp/cakephp/src/Error/ExceptionRenderer.php(118): Cake\\Http\\ServerRequest::createFromGlobals()\n#5 /usr/local/www/apache24/data/passbolt/vendor/cakephp/cakephp/src/Error/ExceptionRenderer.php(91): Cake\\Error\\ExceptionRenderer->_getController()\n#6 /usr/local/www/apache24/data/passbolt/vendor/cakephp/cakephp/src/Error/ErrorHandler.php(137): Cake\\Error\\Exceptio in /usr/local/www/apache24/data/passbolt/vendor/cakephp/cakephp/src/Error/ErrorHandler.php on line 181
Don’t know how to resolv this
Thanks
Hello @oasisck,
Can be a false positive returned by the healtheck.
Is your install working as expected despite these errors ?
Cheers
Hello, thanks for your reply,
No it isn’t, I got http error 500 when I browse URL of passbolt. Then a new line appear in httpd-error.log
Oh yes sorry, I read your report to quickly .
Looks like the application cannot access session primitive functions.
Can you check that the php session package is installed (might be php72-session) ?
Nice one !
Then I got error 404.
Resolved by
AllowOverride All
in httpd.conf
Merci :wink:
