Hi @pimzwagerMCS,
Can you share your passbolt.php (after cleaning db and mail credentials of course)?
Max
Hi @pimzwagerMCS,
Max
<?php
* Passbolt ~ Open source password manager for teams
* Copyright (c) Passbolt SA (https://www.passbolt.com)
* Licensed under GNU Affero General Public License version 3 of the or any later version.
* For full copyright and license information, please see the LICENSE.txt
* Redistributions of files must retain the above copyright notice.
* @copyright Copyright (c) Passbolt SA (https://www.passbolt.com)
* @license https://opensource.org/licenses/AGPL-3.0 AGPL License
* @link https://www.passbolt.com Passbolt(tm)
* @since 2.0.0
* 2. set the variables in the App section
* 3. set the variables in the passbolt section
return [
'App' => [
'fullBaseUrl' => 'cleanedupURL',
// Database configuration.
'Datasources' => [
'default' => [
'host' => 'localhost',
//'port' => 'non_standard_port_number',
'username' => 'passboltadmin',
'password' => 'cleaneduppassword',
'database' => 'passbolt',
// Email configuration.
'EmailTransport' => [
'default' => [
'port' => 25,
'username' => 'user',
'password' => 'secret',
'tls' => null,
//'timeout' => 30,
//'client' => null,
//'url' => null,
'Email' => [
'default' => [
'from' => ['p.zwager@mcs-nl.com' => 'Passbolt'],
//'charset' => 'utf-8',
//'headerCharset' => 'utf-8',
* DEFAULT PASSBOLT CONFIGURATION
* This is the default configuration.
* It enforces the use of ssl, and does not provide a default OpenPGP key.
* If your objective is to try passbolt quickly for evaluation purpose, and security is not important
* you can use the demo config example provided in the next section below.
'passbolt' => [
// GPG Configuration.
'gpg' => [
// If putenv is set to false, gnupg will use the default path ~/.gnupg.
// For example :
// - Apache on Centos it would be in '/usr/share/httpd/.gnupg'
// - Apache on Debian it would be in '/var/www/.gnupg'
// - Nginx on Centos it would be in '/var/lib/nginx/.gnupg'
// - etc.
//'keyring' => getenv("HOME") . DS . '.gnupg',
//'putenv' => false,
// Main server key.
'serverKey' => [
'fingerprint' => '',
//'public' => CONFIG . 'gpg' . DS . 'serverkey.asc',
//'private' => CONFIG . 'gpg' . DS . 'serverkey_private.asc',
in the errorlog:
2021-09-17 08:11:46 Error: [Cake\Database\Exception\MissingConnectionException] Connection to Mysql could not be established: SQLSTATE[HY000] [1044] Access denied for user 'passboltadmin'@'localhost' to database 'passbolt' in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Database/Driver.php on line 140
Caused by: [PDOException] SQLSTATE[HY000] [1044] Access denied for user 'passboltadmin'@'localhost' to database 'passbolt' in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Database/Driver.php on line 132
Request URL: /auth/login?redirect=%2F
Referer URL: https://pb.mcs-nl.com/auth/login?redirect=%2F
Client IP: cleaned up
Can you use the code tag to format it to see where are the comment please
I edited my first posts with code
So I checked MySQL, and I am able to log in with the user and password in the config file, but the passboltdb table is empty. Is this filled in a later stage?
I found a mistake in the database name in passbolt.php, changed it and now in the errorlog:
2021-09-17 08:30:16 Error: [Cake\Database\Exception\DatabaseException] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'passboltdb.actions' doesn't exist in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Database/Schema/Collection.php on line 142
Caused by: [PDOException] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'passboltdb.actions' doesn't exist in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Database/Statement/MysqlStatement.php on line 39
Can I find the default tables somewhere to import them?
Hi @pimzwagerMCS,
Following Passbolt Help | Install Passbolt CE on Debian 10, at the step 2, you should see a wizard for the setup of Passbolt. It is this wizard who will create the database and the /etc/passbolt/passbolt.php
configuration file.
You can safely delete the /etc/passbolt/passbolt.php
file on your server, and the configuration wizard will be available again. It will populate the database.
YES! this seems to have fixed the issue. I am niow configuring the server! Thank you all so much!
Great don’t hesitate to get in touch if you have some other questions
