Hi All,
I am looking to upgrade to V3 but the upgrade instructions says only version 20? Can anyone confirm if I can just follow those for 18.04.5 LTS?
Hi All,
@NoCause unfortunately you cannot follow the version 20 procedure for Ubuntu 18 since the php requirements (7.3) are not met by default by 18. It is possible to run v3 on 18 but this is not officially supported (to reduce the number of package / system we need to support).
