Hi, i want to build my own arm64 docker image from the following repository website://github.com/passbolt/passbolt_docker.
I issue the following command.
sudo docker buildx build --build-arg PASSBOLT_REPO_URL=website://download.passbolt.com/ce/debian --build-arg PASSBOLT_PKG=passbolt-ce-server --build-arg PASSBOLT_FLAVOUR=ce --build-arg PASSBOLT_COMPONENT=stable -t calanderia/passbolt:3.9.3-ce-multiarch --push --platform linux/arm64 -f debian/Dockerfile .
My Output is:
=> ERROR [ 2/12] RUN apt-get update && DEBIAN_FRONTEND=non-interactive apt-get -y install ca-certificates gnupg && apt-key adv 17.4s
[ 2/12] RUN apt-get update && DEBIAN_FRONTEND=non-interactive apt-get -y install ca-certificates gnupg && apt-key adv --keyserver hkps://keys.mailvelope.com --recv-keys 0xDE8B853FC155581D && echo “deb website://download.passbolt.com/ce/debian buster stable” > /etc/apt/sources.list.d/passbolt.list && apt-get update && DEBIAN_FRONTEND=non-interactive apt-get -y install --no-install-recommends nginx passbolt-ce-server supervisor curl && rm -f /etc/passbolt/jwt/* && rm /etc/nginx/sites-enabled/default && mkdir /run/php && cp /usr/share/passbolt/examples/nginx-passbolt-ssl.conf /etc/nginx/snippets/passbolt-ssl.conf && sed -i ‘s,;clear_env = no,clear_env = no,’ /etc/php/7.4/fpm/pool.d/www.conf && sed -i ‘s,# include PASSBOLT_SSL,include /etc/nginx/snippets/passbolt-ssl.conf;,’ /etc/nginx/sites-enabled/nginx-passbolt.conf && sed -i ‘/listen [::]:443 ssl http2;/a listen 443 ssl http2;’ /etc/nginx/snippets/passbolt-ssl.conf && sed -i ‘s,CERT_PATH,/etc/ssl/certs/certificate.crt;,’ /etc/nginx/snippets/passbolt-ssl.conf && sed -i ‘s,KEY_PATH,/etc/ssl/certs/certificate.key;,’ /etc/nginx/snippets/passbolt-ssl.conf && sed -i ‘s,www-data.*$,root su -s /bin/bash -c “. /etc/environment && $PASSBOLT_BASE_DIR/bin/cron” www-data >/proc/1/fd/1 2>&1,’ /etc/cron.d/passbolt-ce-server && sed -i ‘s/# server_tokens/server_tokens/’ /etc/nginx/nginx.conf && ln -sf /dev/stdout /var/log/nginx/passbolt-access.log && ln -sf /dev/stderr /var/log/nginx/passbolt-error.log && ln -sf /dev/stderr /var/log/passbolt/error.log && ln -sf /dev/stderr /var/log/php7.4-fpm.log:
#0 0.818 Get:1 website://deb.debian.org/debian bullseye InRelease [116 kB]
#0 0.939 Get:2 website://deb.debian.org/debian-security bullseye-security InRelease [48.4 kB]
#0 0.990 Get:3 website://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
#0 1.283 Get:4 website://deb.debian.org/debian bullseye/main arm64 Packages [8072 kB]
#0 1.857 Get:5 website://deb.debian.org/debian-security bullseye-security/main arm64 Packages [232 kB]
#0 1.904 Get:6 website://deb.debian.org/debian bullseye-updates/main arm64 Packages [12.0 kB]
#0 2.930 Fetched 8524 kB in 2s (3554 kB/s)
#0 2.930 Reading package lists…
#0 3.859 Reading package lists…
#0 4.607 Building dependency tree…
#0 4.887 Reading state information…
#0 5.422 The following additional packages will be installed:
#0 5.422 dirmngr gnupg-l10n gnupg-utils gpg gpg-agent gpg-wks-client gpg-wks-server
#0 5.424 gpgconf gpgsm libassuan0 libgpm2 libksba8 libldap-2.4-2 libldap-common
#0 5.425 libncursesw6 libnpth0 libreadline8 libsasl2-2 libsasl2-modules
#0 5.427 libsasl2-modules-db libsqlite3-0 openssl pinentry-curses readline-common
#0 5.433 Suggested packages:
#0 5.433 dbus-user-session libpam-systemd pinentry-gnome3 tor parcimonie xloadimage
#0 5.433 scdaemon gpm libsasl2-modules-gssapi-mit | libsasl2-modules-gssapi-heimdal
#0 5.433 libsasl2-modules-ldap libsasl2-modules-otp libsasl2-modules-sql pinentry-doc
#0 5.433 readline-doc
#0 5.666 The following NEW packages will be installed:
#0 5.667 ca-certificates dirmngr gnupg gnupg-l10n gnupg-utils gpg gpg-agent
#0 5.668 gpg-wks-client gpg-wks-server gpgconf gpgsm libassuan0 libgpm2 libksba8
#0 5.668 libldap-2.4-2 libldap-common libncursesw6 libnpth0 libreadline8 libsasl2-2
#0 5.670 libsasl2-modules libsasl2-modules-db libsqlite3-0 openssl pinentry-curses
#0 5.670 readline-common
#0 6.009 0 upgraded, 26 newly installed, 0 to remove and 1 not upgraded.
#0 6.009 Need to get 10.2 MB of archives.
#0 6.009 After this operation, 21.2 MB of additional disk space will be used.
#0 6.009 Get:1 website://deb.debian.org/debian bullseye/main arm64 readline-common all 8.1-1 [73.7 kB]
#0 6.099 Get:2 website://deb.debian.org/debian bullseye/main arm64 libreadline8 arm64 8.1-1 [160 kB]
#0 6.148 Get:3 website://deb.debian.org/debian-security bullseye-security/main arm64 openssl arm64 1.1.1n-0+deb11u4 [831 kB]
#0 6.229 Get:4 website://deb.debian.org/debian bullseye/main arm64 ca-certificates all 20210119 [158 kB]
#0 6.260 Get:5 website://deb.debian.org/debian bullseye/main arm64 libassuan0 arm64 2.5.3-7.1 [48.0 kB]
#0 6.263 Get:6 website://deb.debian.org/debian bullseye/main arm64 gpgconf arm64 2.2.27-2+deb11u2 [540 kB]
#0 6.273 Get:7 website://deb.debian.org/debian-security bullseye-security/main arm64 libksba8 arm64 1.5.0-3+deb11u2 [115 kB]
#0 6.281 Get:8 website://deb.debian.org/debian bullseye/main arm64 libsasl2-modules-db arm64 2.1.27+dfsg-2.1+deb11u1 [69.4 kB]
#0 6.301 Get:9 website://deb.debian.org/debian bullseye/main arm64 libsasl2-2 arm64 2.1.27+dfsg-2.1+deb11u1 [105 kB]
#0 6.304 Get:10 website://deb.debian.org/debian bullseye/main arm64 libldap-2.4-2 arm64 2.4.57+dfsg-3+deb11u1 [222 kB]
#0 6.309 Get:11 website://deb.debian.org/debian bullseye/main arm64 libnpth0 arm64 1.6-3 [18.6 kB]
#0 6.313 Get:12 website://deb.debian.org/debian bullseye/main arm64 dirmngr arm64 2.2.27-2+deb11u2 [743 kB]
#0 6.325 Get:13 website://deb.debian.org/debian bullseye/main arm64 gnupg-l10n all 2.2.27-2+deb11u2 [1086 kB]
#0 6.372 Get:14 website://deb.debian.org/debian bullseye/main arm64 gnupg-utils arm64 2.2.27-2+deb11u2 [864 kB]
#0 6.393 Get:15 website://deb.debian.org/debian bullseye/main arm64 libsqlite3-0 arm64 3.34.1-3 [750 kB]
#0 6.406 Get:16 website://deb.debian.org/debian bullseye/main arm64 gpg arm64 2.2.27-2+deb11u2 [884 kB]
#0 6.443 Get:17 website://deb.debian.org/debian bullseye/main arm64 libncursesw6 arm64 6.2+20201114-2 [121 kB]
#0 6.473 Get:18 website://deb.debian.org/debian bullseye/main arm64 pinentry-curses arm64 1.1.0-4 [63.0 kB]
#0 6.476 Get:19 website://deb.debian.org/debian bullseye/main arm64 gpg-agent arm64 2.2.27-2+deb11u2 [651 kB]
#0 6.488 Get:20 website://deb.debian.org/debian bullseye/main arm64 gpg-wks-client arm64 2.2.27-2+deb11u2 [517 kB]
#0 6.499 Get:21 website://deb.debian.org/debian bullseye/main arm64 gpg-wks-server arm64 2.2.27-2+deb11u2 [510 kB]
#0 6.524 Get:22 website://deb.debian.org/debian bullseye/main arm64 gpgsm arm64 2.2.27-2+deb11u2 [627 kB]
#0 6.534 Get:23 website://deb.debian.org/debian bullseye/main arm64 gnupg all 2.2.27-2+deb11u2 [825 kB]
#0 6.560 Get:24 website://deb.debian.org/debian bullseye/main arm64 libgpm2 arm64 1.20.7-8 [35.9 kB]
#0 6.573 Get:25 website://deb.debian.org/debian bullseye/main arm64 libldap-common all 2.4.57+dfsg-3+deb11u1 [95.8 kB]
#0 6.592 Get:26 website://deb.debian.org/debian bullseye/main arm64 libsasl2-modules arm64 2.1.27+dfsg-2.1+deb11u1 [101 kB]
#0 6.862 debconf: delaying package configuration, since apt-utils is not installed
#0 6.936 Fetched 10.2 MB in 1s (11.4 MB/s)
#0 6.975 Selecting previously unselected package readline-common.
(Reading database … 6653 files and directories currently installed.)
#0 6.993 Preparing to unpack …/00-readline-common_8.1-1_all.deb …
#0 6.999 Unpacking readline-common (8.1-1) …
#0 7.056 Selecting previously unselected package libreadline8:arm64.
#0 7.060 Preparing to unpack …/01-libreadline8_8.1-1_arm64.deb …
#0 7.078 Unpacking libreadline8:arm64 (8.1-1) …
#0 7.168 Selecting previously unselected package openssl.
#0 7.172 Preparing to unpack …/02-openssl_1.1.1n-0+deb11u4_arm64.deb …
#0 7.178 Unpacking openssl (1.1.1n-0+deb11u4) …
#0 7.315 Selecting previously unselected package ca-certificates.
#0 7.319 Preparing to unpack …/03-ca-certificates_20210119_all.deb …
#0 7.325 Unpacking ca-certificates (20210119) …
#0 7.451 Selecting previously unselected package libassuan0:arm64.
#0 7.456 Preparing to unpack …/04-libassuan0_2.5.3-7.1_arm64.deb …
#0 7.463 Unpacking libassuan0:arm64 (2.5.3-7.1) …
#0 7.517 Selecting previously unselected package gpgconf.
#0 7.522 Preparing to unpack …/05-gpgconf_2.2.27-2+deb11u2_arm64.deb …
#0 7.530 Unpacking gpgconf (2.2.27-2+deb11u2) …
#0 7.628 Selecting previously unselected package libksba8:arm64.
#0 7.633 Preparing to unpack …/06-libksba8_1.5.0-3+deb11u2_arm64.deb …
#0 7.658 Unpacking libksba8:arm64 (1.5.0-3+deb11u2) …
#0 7.723 Selecting previously unselected package libsasl2-modules-db:arm64.
#0 7.728 Preparing to unpack …/07-libsasl2-modules-db_2.1.27+dfsg-2.1+deb11u1_arm64.deb …
#0 7.734 Unpacking libsasl2-modules-db:arm64 (2.1.27+dfsg-2.1+deb11u1) …
#0 7.794 Selecting previously unselected package libsasl2-2:arm64.
#0 7.799 Preparing to unpack …/08-libsasl2-2_2.1.27+dfsg-2.1+deb11u1_arm64.deb …
#0 7.805 Unpacking libsasl2-2:arm64 (2.1.27+dfsg-2.1+deb11u1) …
#0 7.895 Selecting previously unselected package libldap-2.4-2:arm64.
#0 7.900 Preparing to unpack …/09-libldap-2.4-2_2.4.57+dfsg-3+deb11u1_arm64.deb …
#0 7.907 Unpacking libldap-2.4-2:arm64 (2.4.57+dfsg-3+deb11u1) …
#0 8.014 Selecting previously unselected package libnpth0:arm64.
#0 8.019 Preparing to unpack …/10-libnpth0_1.6-3_arm64.deb …
#0 8.027 Unpacking libnpth0:arm64 (1.6-3) …
#0 8.086 Selecting previously unselected package dirmngr.
#0 8.090 Preparing to unpack …/11-dirmngr_2.2.27-2+deb11u2_arm64.deb …
#0 8.145 Unpacking dirmngr (2.2.27-2+deb11u2) …
#0 8.357 Selecting previously unselected package gnupg-l10n.
#0 8.362 Preparing to unpack …/12-gnupg-l10n_2.2.27-2+deb11u2_all.deb …
#0 8.370 Unpacking gnupg-l10n (2.2.27-2+deb11u2) …
#0 8.561 Selecting previously unselected package gnupg-utils.
#0 8.568 Preparing to unpack …/13-gnupg-utils_2.2.27-2+deb11u2_arm64.deb …
#0 8.576 Unpacking gnupg-utils (2.2.27-2+deb11u2) …
#0 8.787 Selecting previously unselected package libsqlite3-0:arm64.
#0 8.787 Preparing to unpack …/14-libsqlite3-0_3.34.1-3_arm64.deb …
#0 8.793 Unpacking libsqlite3-0:arm64 (3.34.1-3) …
#0 8.903 Selecting previously unselected package gpg.
#0 8.907 Preparing to unpack …/15-gpg_2.2.27-2+deb11u2_arm64.deb …
#0 8.931 Unpacking gpg (2.2.27-2+deb11u2) …
#0 9.042 Selecting previously unselected package libncursesw6:arm64.
#0 9.045 Preparing to unpack …/16-libncursesw6_6.2+20201114-2_arm64.deb …
#0 9.051 Unpacking libncursesw6:arm64 (6.2+20201114-2) …
#0 9.119 Selecting previously unselected package pinentry-curses.
#0 9.124 Preparing to unpack …/17-pinentry-curses_1.1.0-4_arm64.deb …
#0 9.130 Unpacking pinentry-curses (1.1.0-4) …
#0 9.207 Selecting previously unselected package gpg-agent.
#0 9.212 Preparing to unpack …/18-gpg-agent_2.2.27-2+deb11u2_arm64.deb …
#0 9.220 Unpacking gpg-agent (2.2.27-2+deb11u2) …
#0 9.306 Selecting previously unselected package gpg-wks-client.
#0 9.311 Preparing to unpack …/19-gpg-wks-client_2.2.27-2+deb11u2_arm64.deb …
#0 9.316 Unpacking gpg-wks-client (2.2.27-2+deb11u2) …
#0 9.384 Selecting previously unselected package gpg-wks-server.
#0 9.389 Preparing to unpack …/20-gpg-wks-server_2.2.27-2+deb11u2_arm64.deb …
#0 9.396 Unpacking gpg-wks-server (2.2.27-2+deb11u2) …
#0 9.482 Selecting previously unselected package gpgsm.
#0 9.487 Preparing to unpack …/21-gpgsm_2.2.27-2+deb11u2_arm64.deb …
#0 9.493 Unpacking gpgsm (2.2.27-2+deb11u2) …
#0 9.569 Selecting previously unselected package gnupg.
#0 9.573 Preparing to unpack …/22-gnupg_2.2.27-2+deb11u2_all.deb …
#0 9.580 Unpacking gnupg (2.2.27-2+deb11u2) …
#0 9.682 Selecting previously unselected package libgpm2:arm64.
#0 9.687 Preparing to unpack …/23-libgpm2_1.20.7-8_arm64.deb …
#0 9.693 Unpacking libgpm2:arm64 (1.20.7-8) …
#0 9.744 Selecting previously unselected package libldap-common.
#0 9.749 Preparing to unpack …/24-libldap-common_2.4.57+dfsg-3+deb11u1_all.deb …
#0 9.756 Unpacking libldap-common (2.4.57+dfsg-3+deb11u1) …
#0 9.813 Selecting previously unselected package libsasl2-modules:arm64.
#0 9.817 Preparing to unpack …/25-libsasl2-modules_2.1.27+dfsg-2.1+deb11u1_arm64.deb …
#0 9.824 Unpacking libsasl2-modules:arm64 (2.1.27+dfsg-2.1+deb11u1) …
#0 9.963 Setting up libksba8:arm64 (1.5.0-3+deb11u2) …
#0 9.979 Setting up libgpm2:arm64 (1.20.7-8) …
#0 9.991 Setting up libsqlite3-0:arm64 (3.34.1-3) …
#0 10.00 Setting up libsasl2-modules:arm64 (2.1.27+dfsg-2.1+deb11u1) …
#0 10.05 Setting up libnpth0:arm64 (1.6-3) …
#0 10.06 Setting up libassuan0:arm64 (2.5.3-7.1) …
#0 10.08 Setting up libldap-common (2.4.57+dfsg-3+deb11u1) …
#0 10.09 Setting up libsasl2-modules-db:arm64 (2.1.27+dfsg-2.1+deb11u1) …
#0 10.11 Setting up gnupg-l10n (2.2.27-2+deb11u2) …
#0 10.12 Setting up libncursesw6:arm64 (6.2+20201114-2) …
#0 10.15 Setting up libsasl2-2:arm64 (2.1.27+dfsg-2.1+deb11u1) …
#0 10.17 Setting up openssl (1.1.1n-0+deb11u4) …
#0 10.19 Setting up readline-common (8.1-1) …
#0 10.21 Setting up pinentry-curses (1.1.0-4) …
#0 10.24 Setting up libreadline8:arm64 (8.1-1) …
#0 10.28 Setting up libldap-2.4-2:arm64 (2.4.57+dfsg-3+deb11u1) …
#0 10.29 Setting up ca-certificates (20210119) …
#0 10.40 debconf: unable to initialize frontend: Non-interactive
#0 10.40 debconf: (Can’t locate Debconf/FrontEnd/Non.pm in @INC (you may need to install the Debconf::FrontEnd::Non module) (@INC contains: /etc/perl /usr/local/lib/aarch64-linux-gnu/perl/5.32.1 /usr/local/share/perl/5.32.1 /usr/lib/aarch64-linux-gnu/perl5/5.32 /usr/share/perl5 /usr/lib/aarch64-linux-gnu/perl-base /usr/lib/aarch64-linux-gnu/perl/5.32 /usr/share/perl/5.32 /usr/local/lib/site_perl) at (eval 16) line 2.)
#0 10.40 debconf: falling back to frontend: Noninteractive
#0 11.29 Updating certificates in /etc/ssl/certs…
#0 12.55 129 added, 0 removed; done.
#0 12.66 Setting up gpgconf (2.2.27-2+deb11u2) …
#0 12.69 Setting up gpg (2.2.27-2+deb11u2) …
#0 12.71 Setting up gnupg-utils (2.2.27-2+deb11u2) …
#0 12.72 Setting up gpg-agent (2.2.27-2+deb11u2) …
#0 13.73 Setting up gpgsm (2.2.27-2+deb11u2) …
#0 13.74 Setting up dirmngr (2.2.27-2+deb11u2) …
#0 13.96 Setting up gpg-wks-server (2.2.27-2+deb11u2) …
#0 13.97 Setting up gpg-wks-client (2.2.27-2+deb11u2) …
#0 13.99 Setting up gnupg (2.2.27-2+deb11u2) …
#0 14.00 Processing triggers for libc-bin (2.31-13+deb11u5) …
#0 14.06 Processing triggers for ca-certificates (20210119) …
#0 14.07 Updating certificates in /etc/ssl/certs…
#0 15.02 0 added, 0 removed; done.
#0 15.02 Running hooks in /etc/ca-certificates/update.d…
#0 15.02 done.
#0 15.32 Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
#0 15.40 Executing: /tmp/apt-key-gpghome.PzSMUDc7m3/gpg.1.sh --keyserver hkps://keys.mailvelope.com --recv-keys 0xDE8B853FC155581D
#0 15.78 gpg: keyserver receive failed: Server indicated a failure
Dockerfile:17
16 |
17 | >>> RUN apt-get update
18 | >>> && DEBIAN_FRONTEND=non-interactive apt-get -y install
19 | >>> ca-certificates
20 | >>> gnupg
21 | >>> && apt-key adv --keyserver $PASSBOLT_SERVER_KEY --recv-keys $PASSBOLT_PKG_KEY
22 | >>> && echo “deb $PASSBOLT_REPO_URL $PASSBOLT_DISTRO $PASSBOLT_COMPONENT” > /etc/apt/sources.list.d/passbolt.list
23 | >>> && apt-get update
24 | >>> && DEBIAN_FRONTEND=non-interactive apt-get -y install --no-install-recommends
25 | >>> nginx
26 | >>> $PASSBOLT_PKG
27 | >>> supervisor
28 | >>> curl
29 | >>> && rm -f /etc/passbolt/jwt/*
30 | >>> && rm /etc/nginx/sites-enabled/default
31 | >>> && mkdir /run/php
32 | >>> && cp /usr/share/passbolt/examples/nginx-passbolt-ssl.conf /etc/nginx/snippets/passbolt-ssl.conf
33 | >>> && sed -i ‘s,;clear_env = no,clear_env = no,’ /etc/php/$PHP_VERSION/fpm/pool.d/www.conf
34 | >>> && sed -i ‘s,# include PASSBOLT_SSL,include /etc/nginx/snippets/passbolt-ssl.conf;,’ /etc/nginx/sites-enabled/nginx-passbolt.conf
35 | >>> && sed -i ‘/listen [::]:443 ssl http2;/a listen 443 ssl http2;’ /etc/nginx/snippets/passbolt-ssl.conf
36 | >>> && sed -i ‘s,CERT_PATH,/etc/ssl/certs/certificate.crt;,’ /etc/nginx/snippets/passbolt-ssl.conf
37 | >>> && sed -i ‘s,KEY_PATH,/etc/ssl/certs/certificate.key;,’ /etc/nginx/snippets/passbolt-ssl.conf
38 | >>> && sed -i ‘s,www-data.*$,root su -s /bin/bash -c “. /etc/environment && $PASSBOLT_BASE_DIR/bin/cron” www-data >/proc/1/fd/1 2>&1,’ /etc/cron.d/$PASSBOLT_PKG
39 | >>> && sed -i ‘s/# server_tokens/server_tokens/’ /etc/nginx/nginx.conf
40 | >>> && ln -sf /dev/stdout /var/log/nginx/passbolt-access.log
41 | >>> && ln -sf /dev/stderr /var/log/nginx/passbolt-error.log
42 | >>> && ln -sf /dev/stderr /var/log/passbolt/error.log
43 | >>> && ln -sf /dev/stderr /var/log/php$PHP_VERSION-fpm.log
44 |
ERROR: failed to solve: process “/bin/sh -c apt-get update && DEBIAN_FRONTEND=non-interactive apt-get -y install ca-certificates gnupg && apt-key adv --keyserver $PASSBOLT_SERVER_KEY --recv-keys $PASSBOLT_PKG_KEY && echo "deb $PASSBOLT_REPO_URL $PASSBOLT_DISTRO $PASSBOLT_COMPONENT" > /etc/apt/sources.list.d/passbolt.list && apt-get update && DEBIAN_FRONTEND=non-interactive apt-get -y install --no-install-recommends nginx $PASSBOLT_PKG supervisor curl && rm -f /etc/passbolt/jwt/* && rm /etc/nginx/sites-enabled/default && mkdir /run/php && cp /usr/share/passbolt/examples/nginx-passbolt-ssl.conf /etc/nginx/snippets/passbolt-ssl.conf && sed -i ‘s,;clear_env = no,clear_env = no,’ /etc/php/$PHP_VERSION/fpm/pool.d/www.conf && sed -i ‘s,# include PASSBOLT_SSL,include /etc/nginx/snippets/passbolt-ssl.conf;,’ /etc/nginx/sites-enabled/nginx-passbolt.conf && sed -i ‘/listen \[\:\:\]\:443 ssl http2;/a listen 443 ssl http2;’ /etc/nginx/snippets/passbolt-ssl.conf && sed -i ‘s,CERT_PATH,/etc/ssl/certs/certificate.crt;,’ /etc/nginx/snippets/passbolt-ssl.conf && sed -i ‘s,KEY_PATH,/etc/ssl/certs/certificate.key;,’ /etc/nginx/snippets/passbolt-ssl.conf && sed -i ‘s,www-data.*$,root su -s /bin/bash -c ". /etc/environment \&\& $PASSBOLT_BASE_DIR/bin/cron" www-data >/proc/1/fd/1 2>\&1,’ /etc/cron.d/$PASSBOLT_PKG && sed -i ‘s/# server_tokens/server_tokens/’ /etc/nginx/nginx.conf && ln -sf /dev/stdout /var/log/nginx/passbolt-access.log && ln -sf /dev/stderr /var/log/nginx/passbolt-error.log && ln -sf /dev/stderr /var/log/passbolt/error.log && ln -sf /dev/stderr /var/log/php$PHP_VERSION-fpm.log” did not complete successfully: exit code: 2 |
Am i doing something wrong?
The machine from where i`m building is an Orange Pi 5. I also tried from a Debian Bullseye VM, same error. Is something related to the deprecated adv-key?
Thank You!
[x ] I have read intro post: website://community.passbolt.com/t/about-the-installation-issues-category/12
