Issues with duplicated folders relations
Hello.
During the update of our passbolt-pro instance we got the following warnings:
2036 issues found in table Passbolt/Folders.FoldersRelations (duplicated folders relations)
2041 issues detected, please re-run without --dry-run to fix.
Do we have something to be worried about and need to be fixed or we can leave it like that.
We have a huge number of records and sometimes it takes like 30 seconds to copy or review a password.
We are running passbolt-pro 4.1.1 on Ubuntu 20.04 LTS
Hi @angel.panayotov
Please check out this link:
Since you are using Passbolt Pro you can always contact Passbolt at support@passbolt.com, for dedicated support on the issue.
