I’ve updated my Passbolt server to passbolt 3 by following this guide: Passbolt Help | Update passbolt source install
Since I’ve updated, I can’t see any password. The loading bar seems to be stuck at 75% of progression and I have nothing in the logs.
I’m on a LAMP stack.
Can someone help me to troubleshoot this problem ?
Can you run the following command and provide us with the output: $ sudo -H -u www-data bash -c "./bin/cake passbolt cleanup --dry-run"
If the command returns errors, you can run it without the --dry-run option to clean the data.
For permissions problems, you can run the following command, it will check your system and propose solutions: $ sudo -H -u www-data bash -c "./bin/cake passbolt healthcheck"
I had the same problem when upgrading from the docker version passbolt/passbolt:2.13.5-debian to 3.0 and it was giving me a bit of a headache. I had to log in to the container and run the cleanup command, which fixed the issue. Thanks for that!
