I need to run another instance of passbolt for failover. Is it possible to just have MySQL db replicated a second server and use it as a failover for passbolt?
Hi @Blacky,
If you connect to your server and run the following command:
sudo -H -u www-data bash -c "/usr/share/php/passbolt/bin/cake passbolt mysql_export"
that you can perform on a regular basis,
sudo -H -u www-data bash -c "/usr/share/php/passbolt/bin/cake passbolt mysql_import"
for… well kind of obvious ![]()
feel free to add the --help at the end of each to see the options
Max
Thank you for the reply. I needed a set up as follows;
You will need also to import the keys to the new server to decrypt the passwords in database
I’m actually working on a post addressing this topic! It won’t be an automatic failover but it is possible
Along with what @Termindiego25 says you can follow the official MariaDB guide on this.
I set this up as a test by essentially just doing a migration to a new server so that passbolt was also installed there, shut down nginx on the 2nd server and set it up as a replica.
If you go with a different domain name for the 2nd server you’ll need to do an account recovery to failover.
Thanks.
I will try later today. Just curious, why shutdown nginx in the send server?
If you use GTIDs it can cause an issue if someone makes a change on the replica. Essentially just to make sure users are on the primary and not the replica
