I’m new on passbolt and encounter an error when using the provided script to install de CE edition of passbolt on a Raspbian OS. The repository update “apt update” gives an error on the passbolt repository and stops the installation:
Err:4 https://download.passbolt.com/ce/raspbian buster Release
404 Not Found [IP: 104.22.70.135 443]
Reading package lists… Done
E: The repository ‘https://download.passbolt.com/ce/raspbian buster Release’ does not have a Release file.
N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
I’ve the newest fresh installed raspbian from a few days ago.
I’ve seen some other repository errors here, but they are or resolved or too old to be relevant or for other repositories.
PS: I’ve seen the same problem with de debian repository.
You could update the /etc/apt/sources.list.d/passbolt.sources and remove the raspbian repository in favour of the debian one as I mentioned before. That should do the trick
