Just gotten to the end of configuring the basics, first few times when using a DNS url and SSL it seemed to fail.
So I’ve ended up setting it up using the IP and no SSL, as for the IP when changing the servername in conf.d it doens’t load the homepage, probably missing something obvious here…
As for the HTTPs connection I’m guessing it’s the same as any other NGINX webserver?
For the last I probably gonna find another topic relevant enough, but for the migration of url I don’t seem to find any that had the same “problem”.
Thanks alot,
Best regards
